mbmb
making blacking thicker
if paint is quite thin [as bitumens go] i want to thicken it a bit as its going onto a narrow boat hull where the paint thickness is the most important thing.  .  its been suggested i use cement powder which would also make it  a bit harder and resist scraping on the canal bottom.  can anyone  foresee any problems with it
thanks
Share this post
Will probably (drastically) reduce the adhesion, which would not be good. A much better approach would be to apply several coats, with the recommended drying time between, up to the recommended thickness.
Share this post
I would suggest it’s better to cover with a number of thin layers as thickening will take a larger percentage off whereas many coats reduces loss over time.
if you must thicken try cornstarch
Edited by NB Lola
Share this post
Stick it in the fridge for a few hours!
What specific blacking are you using? Manufacturer and type please, because the "right" answer depends on exactly what it is, but it won't be cement ...
Share this post
I used driveway repair bitumen paint to fill the surface voids on my steep tarmac drive that tends to get eroded unless the surface is waterproof.  I used cement with bitumen, but the only way I could get it to mix was to sprinkle the cement on the surface, followed by sprinkling the bitumen on top and agitating well with a soft broom.
Not much help, except I couldn't get the 2 components to mix properly in a bucket, and when I tried to apply the poorly mixed product it wouldn't adhere well.  ..... it would have been hopeless on a vertical surface.
Share this post
thanks
How many coats are you planning to put on ?
The norm is 3 coats over 7 days.
1st day to wash and scrub the hull
2nd day to put on 1st coat
3rd day touch up in 'corners' weed hatch around swims etc
4th day 2nd coat
5th day repeat  day 3
6th Day repeat day 4
7th day - relaunch
It depends on conditions but ideally you should allow 24+ hours between coats.
Share this post
If the blacking is a bit thin then you need to remove some solvent.
Either:
Leave the lid off, stirring regularly, till it is thick enough- probably a couple of days this weather.
Or : Bring to the boil ( a gas ring might be a bit spectacular so do it outside and preferably handy for the fire brigade  or use an electric plate) and stir until thick enough.
Or: Add solid lumps of roofing bitumen and stir till dissolved/ goo is thick enough.
N
Share this post
4th day 2nd coat
7th day - relaunch
Share this post
thanks for the good suggestions/advice. i got the idea from a forum where they threw cement powder of the wet paint [not mixing it] in a dutch boatyard [standard practice at that yard] , whats peoples views on this?
using iko pro bitument which i already have but hear is a bit thin. maybe 3 coats!
Share this post
As mentioned above, several thin coats would be better as that will help the bitumen to get into all the pores in the metal.  If you must thicken it just leave the lid off in this heat, the solvent will soon evaporate.
Share this post
As that's a bitumen containing paint, just use it as is.  It claims to be overcoatable in 4 hours, so just keep painting until you run out of it!
If you want more, Wickes have it on special offer this weekend ...
Oh, and don't heat it up or it probably will explode!  It's not a traditional blacking, so some of the usual advice is wrong for the stuff you are using.  Just paint it on and do plenty of coats.
Share this post
am interested to know how it differers from the normal bitumen , are u sure overcoat time is only 4 hours?
how much would a v hull 34 ft take for coat . anyone know?
Share this post
Did you get the instruction sheet with it? It probably has a guideline of different overcoat times for different temperatures, obviously a day like today is going to shorten drying time compared to eg mid winter or 10 deg C in springtime etc.
ETA I found this info: https://www.ikogroup.co.uk/product/ikopro-black-bitumen-paint/ its a bit vague, saying 2-4 hours drying time. Sometimes paints have a time "window" which is best to overcoat them in, after that you need to further wait until its fully dry.
If its quite thin compared to normal blacking, its going to have a high solvent content, so I'd say just paint it on, by the time you've been round the boat once I bet the 2 hours would be up and you could go round again and again.
Edited by Paul C
Share this post
thanks, very interesting
am still interested to know how it differers from the normal bitumen ,
4 minutes ago, TheBiscuits said:
https://www.ikogroup.co.uk/download/57778/
Technical data sheet.
Drying time: 2-4 hours
Share this post
I would guess if you are doing gunwhales to the bottom of the V, maybe a coat and a half per 5L tin on a 34ft boat.
Don't forget to do inside the weedhatch!
Share this post
17 minutes ago, pearley said:
You could try SML Ballistic Black. It's very thick.
Used this earlier this year, didn't get the same coverage as I am used to from Intertuf. The blacking did flow well and I felt that it will do its job well.
With Intertuf  3 coats went on, Ballastic black gave 2 full coats and 1 more along the waterline. This on a 60ft boat. It was also much cheaper almost £50 saving.
Share this post
MSDS sheet states it is harmful for aqatic life
Edited by smiler
Share this post
So does the info that comes with International boat was & wax. I conclude that is relating to what is in the can, not when it has cured.
Share this post
notgytg
yet
any one know how to enter a reply, not intuitive at all
just bought 45 litres of it [ less than half price though] , i'll have to paint everybody's boat i think
Edited by mbmb
Share this post
3 minutes ago, mbmb said:
notgytg
yet
Type in the box that says "reply to this topic"
Edit to add :
Located at the bottom of the page.
Edited by Alan de Enfield
Share this post
OK, don't do what I said and paint until it runs out - I thought you would have 2 or 3 5L tins! :D
I'd say probably 4 or 5 coats would be plenty, but see how it goes on and how it dries. As you already have it, get a couple of coats on and see what happens.  If you still have 2/3rds of it left when you have finished, flog it to someone else ...
Share this post
