Paul Ches
Tiller Trouble!
Can anyone advise please? The tiller on our 45 footer has suddenly gone very heavy when pushing tiller over to starboard (bow to port). It suddenly happened without being aware of hitting anything. On the day I put it down to strong sidewind but it's been the same ever since. Have to really put you weight i to steering. Tiller also seems slightly off centre when going straight. Weed hatch is clear and rudder too, so far as I can tell. Any advice appreciated!
Share this post
Sounds to me like you have lifted it out of the cup? Did you sill it or go astearn a little heavy and force the rudder upwards on the bank or something?? Its easy to knock it out. Also usualy fairly straightforward to put back in.
Share this post
If the bottom of the rudder has lifted out of its cup, and dropped to one side, it could be difficult to turn one way, but not necessarily the other.
Can you get your hand right down to the bottom of the rudder and its 'swivel' point ?
Share this post
Alternatively, I've had a springy branch trapped against the rudder and the swim do this. It was out of the way of the prop and gave the symptoms you describe. Could be hard to spot through the weed hatch if the water is murky. Most likely it has been lifted out of the cup as others have described, but this is also a possibility.
Jen
Share this post
Thanks a lot to all three of you. Really helpful. Sounds like tiller might have lifted out of the cup!
So I'll explore further asap. I'm back home in Wales now, and it'll be  2 or 3 weeks before I get back to the boat, but I'll take a look and comment further then.
Thanks all, Really appreciate the tips!
Paul
Share this post
This happened to me, had to get in the water to re-locate it.  I did not appreciate the comments from passers-by.
Share this post
Saw a hire company sort the problem a couple of years ago. Guy turned up with a ladder and a pair of chest waders. 5 minutes, job sorted. Impressed.
Share this post
Its the luck of the draw, I followed a hire boat up the locks on the Mac who had his rudder out of the cup. I stood on the back deck, but a shoulder under the swan neck and in it popped. hero of the day. I bet I couldn't do it again
Share this post
