Sign in to follow this
Sweeny Todd
Ford Transit 03 plate power steering
Nothing to do with boating at all, but we seem to have a lot of knowledge on here so.....does anyone have any advice on the following.
I have changed my high pressure power steering pipe on my transit. It comes with a one use nut which I screwed on first as instructed. Fitted it all fine both ends, started the van and poof, the end that pushes into the nut blew out. I have ordered a new nut from the ford garage, but the question is, will the same happen again when I re do it? At £22 a nut I am a bit wary of having to keep buying them.
Share this post
Ebay has them at a tenner.  However ……. Chinese? After Market? Who knows.
My suspicion is that the recommendation may be to replace not only the nut but the pipe assembly too.
I fear the nut may be the weakest part of the setup.
Share this post
I thought Sweeny said he replaced the Pipe ?
http://www.catcar.info/ford/?lang=en&l=bWFya2V0PT1ldXJvfHxjYXRfaWQ9PTYyNXx8Y2FiYnI9PUZZfHx0aGs9PTB8fHN0PT02MHx8c3RzPT17IjIwIjoiRXVyb3BlIiwiMzAiOiJUcmFuc2l0IEZZIDIwMDAtMjAwNiIsIjQwIjoiSCBTdGVlcmluZyBHZWFyIC0gR2VhciBDaGFuZ2UiLCI1MCI6IkgwMiBTdGVlcmluZyBHZWFyIC0gR2VhciBDaGFuZ2UuU3RlZXJpbmcgU3lzdGVtcyIsIjYwIjoiSDAyMDIwIFN1cHBseSAmIFJldHVybiBIb3NlcyAtIFBvd2VyIFN0cmcifXx8YWxwaGE9PUh8fGdyb3VwPT1IMDJ8fHNlY3Q9PUgwMjAyMHx8c2V0PT1GWUgwMnx8aW1nPT1HMDAyMDEyMjA5fHxmMTI9PTE2ODA5NTM2KzA%3D
Share this post
Thanks for the replies guys. I went to the ford garage in the end as I also suspected the nut might be the weak link. Bought a replacement nut, and it seems to have done the trick.
Share this post
