Sign in to follow this
Pagefield
Wigan Flight Restrictions Back On
14 minutes ago, Midnight said:
If it's just a vandalism thing why not just use a BW watermate padlock at each end?
Because watermate keys are not secure or unique. Plenty on Ebay.
Share this post
But if the required key was truly unique only the one keyholder would be able to use it ?
Share this post
Could it be that there is some other reason besides vandalism....
surely not.....
if having some restrictions means that some lockies monitor the water levels Etc then that’s got to be good thing.
Share this post
I’m not sure they really intended to lift the restriction on Wigan. I think it just got added to the original “lifting” email by mistake.
When we came up a few weeks back it was tricky to get up Poolstock due to levels dropping overnight. Imagine if the little darlings had been able to play overnight as well.
Share this post
IIRC these time slots were originally created when there was a serious issue with one of the locks a couple of years ago which required assisted passage.  The unintended consequence was that the few boats that wanted to run the gauntlet each day stacked up at each end of the flight, which made the passage much easier for all concerned.  The state Wigan is in at the moment I think it makes sense to keep these restrictions, regardless of any considerations about water levels.
Share this post
We did Wigan a few weeks ago, without any help from volockies. Seemed fairly OK to me. What do you mean by the “state”?
I worry that if CRT works out that by putting such restrictions on other flights they can be less concerned about leakages, maintenance etc, we may end up with more flights with very restrictive times.
Share this post
IMHO Wigan is the hardest work of any of the recognised flights but I was referring to the town in general.  I've done the flight loads of time and it is never a pleasant experience but it is easier if you have a bit of company which is what the restrictions promote.  It's one of the few locks where I'm actually pleased to see a queue.
Share this post
It is quite hard work but IMO there is nothing exceptional about it. When we did it we just chuntered up with no hassle. Didn’t seem to be any issue with the natives. Yes definitely easier with another boat, which is what we did. But I was imagining something horrendous from its reputation, which it wasn’t.
But yes we went shopping in Wigan itself, and it hasn’t got much to commend it!
Share this post
But it does have a bakers where you can have your favourite pie in a barm cake!!
Share this post
If you took it back to the boat and put it in the oven you could have your cake and heat it.
Share this post
Don't you mock the legendary Wigan Burger!
Share this post
We were in the middle of the flight when the lockie got a phone call from CRT telling him the restrictions were lifted. They decided to lock it anyway at the usual time for that day as they had no lockies organised for the afternoon, but then it was to be unrestricted from the next day he said.
For us the main annoyance in the flight was the weed at the top lock. I cleared the prop when on the landing and got so much weed on the prop in 50 yards that I lost all forward movement and had to pull the boat in. The duck weed was so thick on one overflow that the water level of the pound was high and 2 boats in front of us had some real problems with water coming over the top of the gates onto their deck. The lockie was quite worried till they got it sorted.
Share this post
There is certainly a lot of weed just at the top, but then clear after a couple of hundred metres.
At the top lock at Johnson’s Hill locks, they have stacked up a large pile of weed near the top gate. Unfortunately above the Wigan flight it would be a massive undertaking.
Share this post
Not quite so clear, further up the canal the weed is quite a problem, going through Blackburn I was down the weed hatch 10 times before giving up and accepting that our forward motion would be slow. Several boaters complained to us about the weed they encountered.
We went up the L&L a couple of weeks ago and had no problems with weed, but it was quite an issue coming back.
Share this post
We’ve just come up through Blackburn. It was fairly slow progress with the weed, but managed it without a visit down the hatch. Also slow through Rishton.
Share this post
Just read on Facebook that a boater who missed the time slot coming down cut the locks off
I can’t help being quite pleased about that!
Share this post
The padlocks locking the paddles on the bottom lock m didn’t look very strong when we passed through early last week.
I certainly wouldn’t condone their actions, but it wouldn’t take much doing.
Share this post
One has to consider why they are on. Ostensibly for anti-vandalism. But can someone explain how putting a very severe restriction on this flight and padlocking just the top and bottom, has any effect on vandalism? All the locks have anti vandal locks which of course are not particularly vandal proof. So any naughty kids with a key can, for example, drain all the intervening pounds. All 21 of them. Which is a lot of water. And if they had any initiative, cut off the rather pathetic padlocks with your average bolt cutters or hacksaw.
So I question whether restricting entry to this flight to a couple of hours a day, is justified. Where is the evidence?
My suspicion is that it is down to the volockies who have annexed this flight as their own plaything, and don’t like the idea that boaters might be allowed to use this pretty average flight of locks when they are not there. I see it as the thin end of the wedge for CRT passing power to volockies and increased restriction on other flights for no good reason.
Share this post
