Craig1 Posted August 5, 2019 Report Share Posted August 5, 2019 Hi all Title says it all really, I need to remove the tape tramlines off my boat. They won't scrape off, so I thought either heat gun or chemical. Not sure how hot the gun gets as don't want burning paint. Any thoughts? Link to comment Share on other sites More sharing options...
haggis Posted August 5, 2019 Report Share Posted August 5, 2019 If they are vinyl, heat from something like a hair drier will loosen them enough for you to lift them off. haggis Link to comment Share on other sites More sharing options...
Craig1 Posted August 5, 2019 Author Report Share Posted August 5, 2019 Thanks, I'll give it a go. Link to comment Share on other sites More sharing options...
cuthound Posted August 5, 2019 Report Share Posted August 5, 2019 8 minutes ago, haggis said: If they are vinyl, heat from something like a hair drier will loosen them enough for you to lift them off. haggis However if they are painted on, then they will need to be sanded off, this will damage the paint either side of them, as you need to remove all trace of them or the "shadow" of them will still show through when you repaint. Link to comment Share on other sites More sharing options...
MtB Posted August 5, 2019 Report Share Posted August 5, 2019 1 hour ago, Craig1 said: Hi all Title says it all really, I need to remove the tape tramlines off my boat. They won't scrape off, so I thought either heat gun or chemical. Not sure how hot the gun gets as don't want burning paint. Any thoughts? Yes. Don't let a tram run over your boat in the first place. Or have I misunderstood? Welcome to the forum, by the way!!! Link to comment Share on other sites More sharing options...
cuthound Posted August 5, 2019 Report Share Posted August 5, 2019 Just now, Mike the Boilerman said: Yes. Don't let a tram run over your boat in the first place. Or have I misunderstood? I suppose it's called progress, trams having replaced coaches in many city centres. ? Link to comment Share on other sites More sharing options...
matty40s Posted August 5, 2019 Report Share Posted August 5, 2019 It will depend on how long they have been on and also what colour!! As to how easy they will be to remove if vinyl. I use a new Stanley blade and low power heat gun, hoping to get the whole lot off in one strip, which never happens. White and red tend to degrade badly, and will come off in many bits, dark colours can come off in long strips. If they have been painted on...sanding them off is the only solution, and repainting the surrounds.....which will look crap unless you have a new 4" coachline in a new colour over the original area. Link to comment Share on other sites More sharing options...
Craig1 Posted August 6, 2019 Author Report Share Posted August 6, 2019 right, heat gun or hairdryer it is, thanks for the help. Link to comment Share on other sites More sharing options...
