Derek Porteous
Eberspacher D 4 W SC
I have an Eberspacher central heating system. It’s start up OK but recently has been cutting out completely randomly before its timed sequence of an hour’s running is complete. Sometimes it goes the whole hour and sometimes anywhere within the hour (10 minutes, 30 minutes, 45 minutes, etc.,). It seems to be completely random when it turns itself off.
Anyone any ideas what the issue is?
Thanks.
Share this post
Do you have a controller with the facility to read fault codes? If you have the 701 controller, see Operating Instructions for how to read them. I found a service cured my similar symptoms after various issues.
Share this post
Thanks.
Could your room thermostat be set too low ?
(We have been having temperatures in the 20's recently)
Share this post
Thanks for replies. I suspect the issue is thermostat related, although we do not have a maximum room thermostat, only a frost control. Guess we need to bite the bullet and get it serviced. We have been advised in the past to make sure we run it at least once a month and then leave it along until it breaks down!
Share this post
You could try the fuel filter. It's so tiny you can hardly see it...about 4mm wide and 6mm long.
It's in the clicking metering pump...where the fuel pipe attaches. You have to remove the inlet pipe and poke about with your nail to get it out.
it's like a tiny thimble. Worth a check before you commit to expense.
Edited by Bobbybass
Share this post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
