Help to pass BSS and electrical issues
B2019
7 minutes ago, B2019 said:
How is this looking now?
The idea is that you have only have one cable on each terminal (except where linking batteries together).
A SINGLE cable should go from the Black (negative) terminal to the busbar, and then all other cables / wires are tapped off the busbar, and then the same for the red (positive)
It looks as if you still have a 'multi-legged' spider on both your + & - terminals.
Atm I have wire from ground (the boat) to negative terminal, wire to inverter, wire to Bush bar and wire for solar. So should I connect inverter to Bush bar and wire from solar to Bush bar?
I wouldn’t move the inverter cables to the busbar. Leave them going direct to the battery.
It doesn't make sense. Negative point - 1. Cable to earth, 2nd cable next battery, 3rd cable to inverter, 4th cable to Bush bar and then 5th cable for solar panels. Of course it looks like a spider but what else can I do?
You could move the solar charger to the busbar. That would be one less.
BUS bar.
Move cable 1 to the bus-bar and then from the bus-bar to 'earth'.
I would move the inverter cable to the bus bar.
I'd leave the Soar cable on the terminal.
Perfect thanks. When I move the earth cable to the bush bar do I actually need a cable running from the negative terminal to the bush bar?
If you have lots of cables on it is becomes a "Busy Bar"
if you have too many it might even become a bust bar.
PS: when I had a widebeam all the negatives went to studs fixed to the hull - in my case there was a 30mm lip where the uxter plate overhung the joint with the vertical swim, so I just drilled and fitted three 10mm set screws.   Positives went to a proper bus bar with an insulated base.
4 hours ago, Mike the Boilerman said:
Buzz bar, anyone?
That is how the lecturer at Wigan Technical College used to pronounce it. In Wigan some pronounce the vehicle "Bus" as "Buzz." i.e. "I'm late for't buzz."
Good job you didn’t drill on the other side of the weld... ;)
On 3 July 2019 at 00:08, B2019 said:
Yeah it does. I bought the cap from ASAP supplies.
"The Perko diesel deck filler suits 38mm (1-1/2") diesel hose and 16mm (5/8") vent hose. This 0540 deck filler features an integral tank vent with a flame arrestor gauze and an anti-surge valve".
U.S.C.G. Safety Standards, 33 CFR 183
U.S.C.G is United States Coast Guard.
That standard might not be comparable to the B.S.S test that your boat must pass.
Bod
