magpie patrick
Inflatable canoe - leaking valve
Pic of canoe and suspect valve below. Bubble come up when inflated and the chamber affected is not canalworthy after about half an hour.
The leak is in the seal shown, no matter how hard you screw the valve in, it leaks.
My thoughts are rather than £60 plus labour etc for a new bladder this must be easily fixable, even if it requires a coat of something on every inflation. The question is what to use. Any ideas?
Thanks folks!
Share this post
Thanks folks!
I would try a new O ring and/or slip an additional one down the screw thread as a first attempt. If only on the grounds that it is a simple thing to test.
Share this post
Thank you - closer examination reveals that the troublesome valve doesn't actually have an o-ring!!! The others do!
Share this post
In the absence of an O-Ring - Wrap clingfilm or plumbers tape around the threads and try again.
Edit to add :
There does look to be an O-Ring squashed inside the female thread - is there ?
Edited by Alan de Enfield
Share this post
Update - new o-ring almost worked, very slight leak (tiny bubbles) which can probably be solved with a little ingenuity and use of something like vaseline to get a better seal
BUT  (you knew there was one coming) the missing o-ring hid another problem. Leaking from the back of the valve where it joins the skin and the bladder. (See photo)
Lady who owns the canoe wants to take it to retailer and raise hell. Two problems, first it's well out of guarantee (3 years old 1 year guarantee - although she reported a leak within the guarantee period that they claimed they'd fixed), second she wants me to go with her, and whilst I would describe them as chocolate teapots in the technical department I think we haven't a leg to stand on.
Any suggestions for what might seal the back of the valve - I don't want to use something that fails and can't easily be removed.
Share this post
I'm not quite sure where the tiny bubbles are coming from so this might not be the best idea I've ever had but instead if Vaseline could you use something a bit more permanent like Sugru. It's brilliant stuff and most of my best ideas involve the use of it. :D
https://sugru.com
Share this post
https://sugru.com
Looks good - I'd never heard of it!
Share this post
It is really handy stuff and once you get the hang of it you can find all sorts of things to fix. :D
Share this post
Some of which actually need fixing....
  • Haha 2
Share this post
The valve body screws together sandwiching the material between. With the canoe deflated you should be able to get enough grip on the inside piece (hint - the further within reason you grip through the body the more slack you get)
Option 1 - try and tighten
Option 2 - carefully loosen, clean and tighten. DON'T let go the inside piece (hint - have a helper)
Share this post
https://sugru.com
Is it oil resistant?
If so I could use it to fashion a new "O"  ring for the scraper on my drip feed oil stove.
Share this post
The new Duck Tape...
If you can't fix it with Sugru, you haven't used enough....
Share this post
And if the hammer hasn’t repaired it the hammer was too small.
Duck tape is The Force. It holds the universe together.
Share this post
1 hour ago, WotEver said:
Duck tape is The Force. It has a dark side, a light side and holds the universe together.
Corrected that for you...
Share this post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
