Donal Boland Posted April 17, 2019 Report Share Posted April 17, 2019 Has any one used a product from a company called Soprema to overcoat bitimum 15 20 year lifespan Prime first the finish coat Primar Aslan 170 Test patch to be completed first to select the right primer Looks like a way to overcoat bitimum Link to comment Share on other sites More sharing options...
Alan de Enfield Posted April 17, 2019 Report Share Posted April 17, 2019 9 minutes ago, Donal Boland said: Has any one used a product from a company called Soprema to overcoat bitimum 15 20 year lifespan Prime first the finish coat Primar Aslan 170 Test patch to be completed first to select the right primer Looks like a way to overcoat bitimum Why would you want to paint over bitumen ? Link to comment Share on other sites More sharing options...
Donal Boland Posted April 17, 2019 Author Report Share Posted April 17, 2019 Because it needs relcoating every two years Link to comment Share on other sites More sharing options...
Alan de Enfield Posted April 17, 2019 Report Share Posted April 17, 2019 1 minute ago, Donal Boland said: Because it needs relcoating every two years Surely any bitumen that is still attached (after a jet wash or whatever) is just painted over by new bitumen ? (Well in my experience anyway) Link to comment Share on other sites More sharing options...
Donal Boland Posted April 17, 2019 Author Report Share Posted April 17, 2019 Yes that is normal but must be done every few years this product has a 20 year lifespan Link to comment Share on other sites More sharing options...
Alan de Enfield Posted April 17, 2019 Report Share Posted April 17, 2019 4 minutes ago, Donal Boland said: Yes that is normal but must be done every few years this product has a 20 year lifespan If you are just overpainting the existing 'blacking' surely the adhesion of the 'new paint' s only as good as the adhesion to the existing blacking, and the existing blacking to the steel hull. Are you suggesting that there is no need to sand-blast the hull and get rid of the old paint and mill scale ? Link to comment Share on other sites More sharing options...
Donal Boland Posted April 17, 2019 Author Report Share Posted April 17, 2019 Yep Link to comment Share on other sites More sharing options...
mark99 Posted April 17, 2019 Report Share Posted April 17, 2019 Donal are you promoting this product? 1 Link to comment Share on other sites More sharing options...
Donal Boland Posted April 17, 2019 Author Report Share Posted April 17, 2019 No just found it and am thinking of using it Wondered if any one else had used it as bitimum is not a great product Link to comment Share on other sites More sharing options...
Alan de Enfield Posted April 17, 2019 Report Share Posted April 17, 2019 1 minute ago, Donal Boland said: No just found it and am thinking of using it Wondered if any one else had used it as bitimum is not a great product Sounds to me it should be on the same shelf as the snake-oil.. Good luck. If it works as well as you hope, please do come back in a few years and let us know. Link to comment Share on other sites More sharing options...
Donal Boland Posted April 17, 2019 Author Report Share Posted April 17, 2019 Have you researched it of just chatting ? Link to comment Share on other sites More sharing options...
dmr Posted April 17, 2019 Report Share Posted April 17, 2019 Standard blacking, redo every 2 years, maybe 3 if lucky. Epoxy, good for 7 to 10+ years but may need scrapes patching up every 3 or 4 years. Anything else...if it sounds too good to be true then it almost certainly is. ..................Dave Link to comment Share on other sites More sharing options...
Captain Pegg Posted April 17, 2019 Report Share Posted April 17, 2019 These are waterproofing products for buildings and structures. Alsan 170 is apparently a primer for concrete. ? JP Link to comment Share on other sites More sharing options...
Donal Boland Posted April 17, 2019 Author Report Share Posted April 17, 2019 Used on fishing boats that would have more ware and tare Link to comment Share on other sites More sharing options...
Sea Dog Posted April 17, 2019 Report Share Posted April 17, 2019 5 minutes ago, Donal Boland said: Used on fishing boats that would have more ware and tare Well, if someone (you?) tries it and it proves effective on a narrowboat - there'll be a queue! Do keep us abreast of your findings if you learn more Donal. Link to comment Share on other sites More sharing options...
Donal Boland Posted April 17, 2019 Author Report Share Posted April 17, 2019 I will let you know how the sample works out worth looking at Link to comment Share on other sites More sharing options...
LadyG Posted April 17, 2019 Report Share Posted April 17, 2019 3 hours ago, Donal Boland said: Yes that is normal but must be done every few years this product has a 20 year lifespan D you happin to sall it? 2 hours ago, Donal Boland said: No just found it and am thinking of using it 30 minutes ago, Donal Boland said: I will let you know how the sample works out worth looking at It;s OK, let us know in ten yeaars, no problim. Link to comment Share on other sites More sharing options...
Captain Pegg Posted April 17, 2019 Report Share Posted April 17, 2019 1 hour ago, Donal Boland said: Used on fishing boats that would have more ware and tare What product are we talking about? Soprema make waterproofing products for buildings not paint systems for boats. The reason bitumen isn’t effective long term on boats is because it gets worn off by mechanical action and attacked by petro-chemicals floating on the water. Unless you know of a specific product for coating steel and adhering to bitumen you seem to be proposing substituting products formulated for the job at hand for ones that aren’t. In what environment is the product you are proposing meant to last for 20 years and with what application requirements? JP Link to comment Share on other sites More sharing options...
Nightwatch Posted April 17, 2019 Report Share Posted April 17, 2019 Bump it, break the surface and you're back to square one, bitumen. Back in drydock for doing again. I agree, worth a shot. But not on my boat. Link to comment Share on other sites More sharing options...
Chris Williams Posted April 17, 2019 Report Share Posted April 17, 2019 4 hours ago, Donal Boland said: bitimum is not a great product There are various grades of Bitumen. I used a tar-like product from the Coal Board. I would suggest that 'Bitumen Paint' is an inferior product. Not an expert, just gut feeling. Link to comment Share on other sites More sharing options...
