Hi i have a dm2 which has had a top end averhaul. Since overhaul i have had running issues, it splutters and coughs randomly for abit ( can be 5 seconds can be 5 minutes) . Injectors have been done injector pump has been done exhaust valves have been done new oil and filters new fuel and air filter. Any ideas please.
Share this post
Air in the fuel lines?
If so check for the fuel system for air leaks and bleed the injectors.
Share this post
On 04/04/2019 at 12:45, Mike the Boilerman said:
Get the bloke back who did the top end rebuild!
+1
Share this post
After weeks of issues finally tracked down air leak it was the glass bowl on lift pump not seating correctly.... happy boating everone.
Share this post
Glass? Is that BSS compliant?
Share this post
No it isn't but you knew that didn't you?
It is also a good example of one of those stupid BSS rules that can safely be ignored in my opinion.
(As opposed to most of them which are sensible and good.)
:icecream:
Share this post
Nobut it is for the far more stringent MCA inspection :banghead:
Share this post
Not according to this:
https://books.google.co.uk/books?id=PDI8DwAAQBAJ&pg=PP39&lpg=PP39&dq=bss+compliant+glass+bowl&source=bl&ots=YvENwi8hiY&sig=ACfU3U33Jv40sLj7oW3jHxN-7cAZJLiY6w&hl=en&sa=X&ved=2ahUKEwiRgOPp7f7hAhWjRxUIHTsOBIQQ6AEwDXoECAgQAQ#v=onepage&q=bss compliant glass bowl&f=false
That says glass is OK
Richard
MORE: They are OK for non-private boats according to the BSS:
https://www.boatsafetyscheme.org/boat-examination-and-certification/non-private-boats/part-2-inboard-engines/fuel-filters/
I don't think they are mentioned in the private boat scheme
Edited by RLWP
Share this post
31 minutes ago, RLWP said:
I had to change my water trap glass for aluminium on my first BSC check, 2000.!
Share this post
So did I!
So either examiners are making rules up again, or the rules have changed recently.
Share this post
3 minutes ago, Mike the Boilerman said:
So did I!
Perhaps its another debacle like the all metal spill rails we had to fit, now they allow bits of rubber hose.
Share this post
Changing a glass sedimenter bowl is a very sensible move.........Ive seen the things break just from being tightened to stop a leak,and broke one myself with just a touch of a spanner.............The catch is the ally bowl is very expensive.............good reason to change to spin ons.
Share this post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
