Grease
Roxylass
17 minutes ago, Roxylass said:
Is there any specific grease to be used when greaseing the crank shaft on the lister sr2
i can get grease catridges from my work but would like to know if there is a certain one to use
Unless you have the engine in bits or its a stationary engine you can't see the crankshaft eccept through the crankcase door.  Do you mean the camshaft, the stub that sticks out where the alternator gets its drive from.
1 minute ago, Roxylass said:
Apologies bizzard it is the camshaft the raised handstart chain goes around it also
I'd oil the freewheel chain sprocket, same as on a bike. You can get chain grease for the chain, or oil it. A drop of oil on the handle shaft upstand bearings.  You could rub some oil over the shaft if you you want, some folk paint it.
