I have a very old Electrolux gas/ 12v fridge which has a problem. Usually I push the control knob in, then the ignition, the flame lights and stays on when I release the knob. Now, the flame lights but goes out when I release the knob. I don't know much about these things but it seems that the thermocouple might of gone. Does this seem likely? If so, does anyone know if this part is available and if so, might replacing it be something simple, that I could do myself? Also would I be right in thinking it would be dangerous to override the thermocouple (if that's what the problem is) by fashioning a way of keeping the knob pressed in while I work out how to repair it?
Share this post
Easy job to replace as it simply unbolts.
Measure the le gth a d try to get a direct replacement from a plumberscmerchsnt.
If not Screwfix do universal kit, but it may be too long, in which case you MAY be able to roll up the excess length, depending on space available.
https://www.screwfix.com/p/standard-universal-thermocouple-900mm/89191?tc=WT7&ds_kid=92700031336593296&gclsrc=aw.ds&ds_rl=1241687&ds_rl=1245250&ds_rl=1249404&gclid=CjwKCAjwmq3kBRB_EiwAJkNDpyQp-6llaiWV4w8XcBozL1MEWilsYp1jhGYIgqutI_DpJT_mBsUy7xoCgKYQAvD_BwE
Share this post
It might just be dirt on the burner. On mine, if it's left a while it won't light. Sometimes you can blow it clean. Alternatively, if the flame has been getting smaller, it can be the jet blocked. This is what was up with mine I think Bizzard suggested cleaning it out with a strand from a wire brush - worked like a charm.
Share this post
Yes you are right, it would be very dangerous to override the thermocouple. If the flame went out, the boat would fill up with gas; I'm sure I don't need to describe the possible consequences.
Share this post
PS mine is at least fifteen years old, and probably more. If the jet gets dirt on it, the flame just isn't long enough to reach the thermocouple. You get all kinds of muck down the chimney, from dust to spiders webs. And the jet blocks up over time, too.
Share this post
Probably thermo couple as others have said, but likely dust as others have said. Buy a can of Air duster, its brilliant for blasting such as this,  I used some to clear my hard to get to oven jets and it worked in seconds. Its cheap as chips on ebay in a purple can by essential electrics or look in poundworld I found some there at a quid a can, a no brainer to try it first :cheers:
Share this post
Its often the air hole at the base of the jet assembly that gets fluffed up resulting in a small flame which fails to heat the thermocouple properly. It won't work if the knob is held in, don't be daft enough to try over-riding safety devices.
Share this post
3 hours ago, The Welsh Cruiser said:
On reflection I don't feel able to fix this. Does anyone know anyone in the north east Cheshire area, suitably qualified, who could fix this for me?
If its just cleaning, or the jet hole reaming out, it really is quite a simple job. If you pull the fridge out and have a look round the back, you can see it all, and it dismantles and goes back together very easily, nothing but a spanner needed. If you do a search on here, you should be able to find a thread I started a year or so back on the same thing, where Bizzard (i think) gave me very detailed information on how to do it.
Share this post
If you can take the fridge out and take it to someone to fix it will be a lot cheaper and less problematic in terms of getting someone suitably qualified.
This guy is in Nottingham - I took my gas fridge to him to fix and he did it in an hour and charged me £50.  http://www.motorhometech.co.uk/index.html
If he's too far he may be able to recommend someone in your area.
Share this post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
