plainsman
Stoppage Information upstream/downstream
The reference to upstream and downstream on CRT Stoppage site has been puzzling me for a while. As there isn't any flow on canals (exceptions I know),  does it relate to nearest lock? What about lock free canals or sections? Is it up and down in relation to big towns/cities as on railways?  Not a major issue but I would like to know.
Share this post
There is flow on all canals! Its not stagnant water.
The usual canal with locks is obvious, flow is down the nearest lock.
On lock free canals there is still a run off somewhere down stream.
Of course the flow reverses when you get to the watershed or where the reservoir feeds in, going both ways.
Share this post
If you were on the Llangollen you'd definitely know which is which!
Share this post
I have always counted upstream as uphill in the case of canals, and I think that ties in with the stoppages.  That said the winding locations quoted often seem to be wrong, or at least very conservative.
Share this post
But just to complicate things a number of canals have a summit level, so from there both directions are downstream......
Share this post
Yes, but that doesn't cause a problem for stoppage notices - by definition the winding hole on the summit pound will be the uphill one for stoppages at either end.
Share this post
4 minutes ago, Alan de Enfield said:
If all the gates/paddles/sluices were left open, which way would the water flow ?
Through the embankment, if it's in Middlewich. :icecream:
Share this post
Interesting as the stoppage notice for Broad Street tunnel has
Up Stream Winding Hole:
Deep Cutting Junction Bridge, junction with Birmingham & Fazeley Canal
Down Stream Winding Hole:
Gas Street Basin
Perhaps upstream is that side as there is a feed from Smethwick and Edgbaston Reservoir even if they are a few miles away.
Share this post
Gas Street Basin
That sounds right to me, Old Turn is the side that has locks above it, the locks up to the old main, so it is the upstream side.  The Gas Street basin side only has locks going down.
Share this post
Yes, I think it demonstrates that given a bit of thought there is probably a rational reason for selecting upstream and downstream.
Share this post
31 minutes ago, ditchcrawler said:
CRT also have a slight problem working out where their winding holes are https://canalrivertrust.org.uk/notice/12842/bridges-204-and-206-little-leigh-trent-and-mersey-canal
If they cannot 'complete a box' they are totally lost.
One of the problems of using staff with no actual waterways skills or knowledge.
Last year a lock was closed on the River Trent and they gave the 'winding holes' location as being at each lock 'either side' of the closed lock which were 10-15 miles away each side..
However the River was about 60-100 YARDS wide at these points. Not much need for winding holes for anything that is likely to be using the River.
Share this post
many have mote than one summit, they go up and down and back up like those poor men we were told about as children.
Share this post
And there are some (fewer?) bottom pounds where locks go up at both ends. eg where the Grand Union crosses the Ouse valley in Milton Keynes, and the Avon in Warwick, the Middle Level navigation at March.  I can't think of any others? I suppose you could count the long pound on the Bridgewater. Oh and the  Witham navigable drains, where the only way is up.
Any more ??
Share this post
Any more ??
The Monty is heading that way
Share this post
Any more ??
There are other interesting locations like Braunston to Napton, were in each direction there is an up and a down.
Share this post
Very nice!  So Hillmorton to Calcutt it is a summit and Braunston to Napton it is a bottom pound. Of course on that stretch you are going north and south at the same time, too...
Share this post
Quite, uphill and down, north and south, at the same time, confused you will be.
Share this post
And some dead end pounds where the lock goes up at the other end e.g. Aylesbury and The Mont (for now).
Edited by David Mack
Share this post
