baldlimey
Everything posted by baldlimey
  1. Hi, Trying to change the starter alternator belt on my beta 38. The new belt I have will just not fit and I was hoping someone could advise the correct belt to get. The old belt is a contitech ax 10×950 and so is the new but the new belt is toothed where the old belt isn't,. The other numbers on the belts (incase these mean something to someone) are 02102017 8 66 (old) 02102017 8 61 (new). Several of us in the marina have tried without succeedsuccess and yes the alternator is adjusted all the way in. Thanks for any help. Pete
  2. Dates have just been announced for Crick 2021 20th to 22nd August. Pete
  4. Hi, I use my phone as a wifi hotspot to stream netflix but not HD (as my telly is not HD) without a problem. And my phone is the original note so I am sure does not do 4G let alone 5. Pete
  5. Are you looking for somewhere you can move to yourself or are you willing to get the boat lifted and moved by truck?
  6. It does not even need to be inexperience, I have replaced many water pumps but when one packed up on a Easter Sunday on a boat we had rented in Dublin the poor owner still ended up coming out as I had no tools, or a spare pump. You could of course leave spares and tools but would you want to trust 'anyone' repairing your boat
  7. I realised I never did put the ebay seller who got me the correct part. I have no connection other than buying the new bleed screw this with them but found them extremly helpful and vey quick at replying. They are radiator-parts Pete
  8. Thank you everyone for the advice A litre of morrisons bio laudary liquid seems to have cured it. Morrisons because we were in stone and that is the local supermarket Pete
  9. Hi, I think the seal around the ball is OK, the bowl retains water fine. I would have thought if I had rust holes I would have had the smell before the bolts were replaced. Anyone ever tried a smoke candle or some thing to check?
  10. Hi When you say he fitted it so the hole is blocked do you mean by accident and caused a problem or deliberately to solve the problem? Cheers Peter
  11. We recently had a problem where the screws holding our toilet flange down broke and had to be replaced. We always had the occasional whiff on flushing, it is a dump through traveller but now it is constant but oddly a sweet sickly smell rather than the more 'traditional' smell. When it was reasembled the person who repaired it seemed to use plenty of a black coloured sealent and I replaced both the Base and bowl seals. I obviously need to disassemble and have another go but anyone got any advice on where to add sealer or test before I do as I am at a bit of a loss. Thanks Pete
  12. Had a bit of a disaster, we have a domestic Sealand dump through pump out toilet and the 8 screws which held the toilet to the top of the tanks all broke. The broken screws have been drilled out tapped and replace. Had to reasemble with the old gaskets as that is all I had. I have the new gasket with new nuts and bolts but the instructions say 'tighten securely'. I am talking about the 4 bolts which hold the Base to the nylon flange. Was wondering if anyone had any further advice about how tight to get those nuts. All help (as always) gratefully received. Peter
  13. Thank you everyone for you advice. If it us useful to anyone it is a myson type 13. VERY easy to change once you have the right part. There is a good seller on ebay am I allowed to mention his name here? Peter
  14. Hi, I am back from the boat with a couple of photos. The fitting does look like it would unscrew, but I did not try to remove it. I did take out the bleed screw and it is not tapered it has a blunt end with a raised circle in the middle, not sure how clear that is in the photo. It is next to a new standard screw for comparison. I did remove another screw and it was the same. Pete Had to do 2 post for 2 photos
  15. I think mine are the old fashioned kind, so just a little brass tapered screw. I will be at the boat this weekend so will check and post pictures. Thanks Peter
  16. Thanks all I will get a picture this weekend. Pete
  17. Hi, I have a bleed screw on a radiator on the boat which just keeps weeping with the central heating pump on or off. It is staining the woodwork below so I would really like to stop it, I have tightened as much as I dare, any brilliant ideas aprreciated. Thanks Peter
  18. Thank you I Could get here but not the crt site for some strange reason. I get a SSL error
  19. The towpath telegraph is saying this is shut Just wondering if anyone has up to date info Cheers Pete
  20. Thanks all Just checked the voltage and it was just over 10 at the fridge and 12.86 at the batteries. When I tightened the earth connection at one end of the batteries I obviously did not tighten properly when I replaced the domestic batteries it went up at the fridge. Doh! I would love to say this was the dumbest question I had asked on this forum. Pete
  21. Hi. My shoreline fridge is acting very strange. If I leave it set on 3 the led starts blinking which I thought meant low voltage? However if when it does this I turn it up to 4 the compressor starts and it seems happy for a time. The domestic batteries are about 2 weeks old. The blinking appears to be one a pause then 2 although it is difficult to be sure. It has been very hot on the boat. Any ideas great fully received. Pete
  22. Hi Do ypu have the contact details for the guy who came and sorted it? How much was it? Cheers Pete
  23. I'm going tp make what is probably a dumb comment. Make sure the diesel valve is off and even then you will still get a regulators worth of diesel when you unscrew the cover. You will probably have guessed that in advance but....
  24. I wasn't sure but I have been using the small version of this on our 54footer to moor in the marina for over a year with no issues. It is mounted on the gunnels about about 35 ft
  25. Thanks all the water is coming out the hole in the top and only if you flush long enough so that and a plastic chinese container is keeping us going. I know what I need to ask for, will call leesan
