Everything posted by Onewheeler
You need a jiggle syphon rather than a spout for transferring from a can. Very easy to use and hard to spill more than a few drops. We carry 200 L in cans on our boat on the mainland as it's very hard to find waterside filling points.
I very recently had to get the olive off the stub end of the pipe coming out of the Webasto to enable me to dismantle it. A bit tricky as the olive was fairly well stuck (aren't they always?) Got it off eventually with a spanner close-fitting around the pipe below the olive on the pipe end, a flat-blade screwdriver held against the end of the pipe and a molegrip pullng the two together. It really needs three hands but I did it unaided. The olive gradually moved up until I could pull it off with some gentle help from the grips.
How much pitting is okay? Merged with Boat Survey
Onewheeler replied to Lisahall24's topic in New to Boating?
What Bee said. 1mm is nothing. I'd have it shot basted and epoxied instead of normal blacking. Budget a bit over £2k for that and anodes (others may have a better cost estimate). -
Swedish crisp rolls, rubbed with garlic, tomato and drizzled with olive oil. A sort of Swedish tostada con tomate y ajo. Five minutes work and Roberto es tu tío.
What is your hot water set up for a bath onboard?
Onewheeler replied to Kristina's topic in Build Blogs
We've got a deck wash valve on t'other boat which produces warm raw water from the engine. I'd not thought of filling a bath from it, but knowing what goes into canals on the mainland I'd give it a miss.- 56 replies
Bath with a friend. We've got one of those "sit" baths. I'm not that tall and fairly slim, and for me it's only as good as a medium-sized shower tray. No way can I get my dangly bits in it but a friend who works in an old people's home says that a bloke's bits dangle lower and lower once they get older. OMBs as she calls them. Something to look forward to. It was good when the kids were tiny, we could fit both of them in at once until the girl-child objected to her brother.- 56 replies
(d) Head up (e) Try not to fart. (f) In case of failure of (e), don't follow through.
Expansion vessel or accumulator (leaky PRV)
Onewheeler replied to Tessy's topic in Boat Building & Maintenance
A separate expansion vessel is only needed (in addition to an adequately sized accumulator) if there is a NRV on the cold feed to the calorifier. The NRV in my opinion only solves a hypothetical problem in most installations and in my opinion. I don't have one on one boat and took it out on the other. No issues with warm water from the cold tap and even if there was it would only need to be run for a few seconds. -
If you have a non return valve between the expansion/accumulator tank and the calorifier the PRV will pass water and you may be in danger of bursting the calorifier. That's the first thing to check. Otherwise it might be a knackered PRV. Twiddling the red knob (oo-err) may help the valve reseat if there is scale there. -
MS Amlin (formerly and soon-to-be-again Haven Knox Johnson) seemed surprised that anyone would ask when I asked last year (the boat then being 26 years old). They always seem nice to deal with and are as cheap as anyone.
https://www.censusjobs.co.uk/
Census workers being recruited now as well. Soe roles better-paid than others...
We had a very small ceremony in our village, possibly the only time that the vicar has discouraged people from attending one of his dos. It was rather moving with just a dozen or so, mostly quite old, people present (plus me, who some might say is quite old but I've got the mind of a sixteen year-old. The sort that mothers warn their daughters about.) As an aetheist I feel it's important to have these rituals, the Remembrance Sunday one always brings a lump to my throat and moisty-eyes.
Those timers will do from 0.3 to 768 s in four ranges. Can't see clearly which range they're set to (you can tell from what's in the little window - see https://www.gastroparts.com/en/part-110942 ). I suspect they might be to delay switching on something like a charger or isolating transformer to spread out a start up surge which would trip a MCB when reconnecting a shoreline supply. You'll have to trace the wires back to see what they're connected to!
Best brand of coal to use in a Morso Squirrel?
Onewheeler replied to Piran's topic in General Boating
Of the restricted range of stuff that I can get readily, phurnacite is my favourite. Low-ish ash, hot, not too expensive. -
Depending on how you feel, it might be easiest to run trunking or conduit either under the gunwhales or at shirting board level. My inclination (what I've done) is to run mains wiring around the boat (keeping it separate from 12 V) and use an invertor or shore power as much as possible. Main exceptions are lighting and some USB outlets which run off 12 V. Our current fridge is 12 V on the UK boat, but when it dies (it's 27 years old) it will be replaced with a mains fridge.
I think you'll find that the speed of the water may be less than you think. Last time I went out in a flood (marginal yellow / red boards) I reckon the current below Osney (where it does whizz through) was mostly around 4 - 5 km / h. It was probably faster above Osney, but it's fast there whenever there's fresh. We made progress but slowly. It was going much faster through Folly Bridge. Beware of bridges, they are dangerous in flood conditions. Even in the 2014 floods I doubt if the current was much faster than that. Calibrated pooh sticks are the easiest measuring device.
Yes. My wording could have been better. I blame the gin. History of science, by the Bodleian. Natural history is going towards the University Parks. A lovely building, I'm always taken aback by how mediocre the view is from the roof of the Ashmolean. Nary a dreaming spire to be seen. A nice place for a drink though when it reopens.
I think you mean the Museum of the History of Science. It's scary when you find exhibits of things that you've owned or used.
Yes! We moor in Oxford but a graduate of the light blue. If one likes art, the Stanley Spencer gallery in Cookham is an essential stop. The Ashmolean in Oxford is good too.
Sleeping bags + mats. Over the years, I've had a double futon / sofa bed (had to cut the end off so it would lay flat across the boat), a big wooden box with a cushion on top (good for sleeping and storage, unsightly and uncomfortable for sitting on) and now a single futon / sofa bed with a storage box underneath (comfy to sit on and a good compromise: something like this https://www.futoncompany.co.uk/sofa-beds/size/single/oak-switch-sofa-bed.html but I paid less than £200 from the same shop in Oxford).
Apologies. I thought you were referring to the workshop manual which I've got from one of the dealers which is not particularly helpful. That link is, I think, the one I was looking for. Ta very much!
Ta! I think that's what is downloaded from Butler's. It was the helpful useful guide with photos that I was hoping to find.
Yes, I'd found that. Someone had written a very detailed set of instructions with photos and I'm fairly sure that it was a pinned post here. Going back several years.
I might be imagining it, but I think there used to be a service / repair illustrated guide here as a sticky post on one of the sub-fora. Can anyone point me to it please? Martin/
