Onewheeler
Everything posted by Onewheeler
  1. I imagine he's not got a delivery address...
  2. Don't forget to book the harbour gates at Lydney! Check that someone is there before setting off. You'd feel a right plonker if you arrived and found them shut. Only alternative then would be to go down to Portishead. VHF marine is useful to maintain contact with Sharpness (or other places in an emergency). And, basically, don't even think about going up the river to Gloucester. It might be an idea to call SARA and see if they fancy launching one of their boats to accompany you as a training exercise. At least you could hand them your camera for a photo!
  3. I've done the crossing to Lydney. Go out from Sharpness about 30 minutes before high water, the tide will take you upstream a bit but the Lydney side reverses early and you'll have a gentle ride down to the harbour entrance. Coming back leave a bit before high water and go straight across. Don't do it on a very high tide or in a high wind.
  4. I only realised recently, and it's not been noticed in six BSS examinations, that the nice louvre vents on the front bulkhead are screwed onto solid sheet steel!
  5. Also worth remembering that self-amalgamating tape breaks up after longs exposure to UV. It's good practice to overwrap it with a good quality insulating tape.
  6. Even better if then covered with Denso tape, but you'll never want to remove it!
  7. You may have an automotive Webasto which needs more volts to start than the marine version. Ours is reluctant to start after a couple of days moored off shore power (but plenty of charge left), and needs a bit of a boost from the engine to get it going. (And before anyone chirps up, the connections are fine!)
  8. Nope, that's very different to mine. Must have been an odd one.
  9. It's the part that makes contact for the high current to the starter motor. Very crude when it was dismantled. Yes, a relay.
  10. I can't remember the ins and outs, but undoing the two or three screws on the end cap enabled access to the big bit of springy copper or brass which could have the contact points filed clean. I think the big bit of springy metal came out with the end cap, but it was twenty years ago...
  11. That looks like the old Duckhams Oil depot. I had a holiday job there in the seventies. The first few weeks I went round the plant collecting empty drums for loading onto a truck, then spent most of the day looking at boats. The management then noticed that I was underemployed and found a warehouse full of out of spec one pint tins of oil that had to be emptied into 200 L drums.
  12. It depends on the model. On my long dead BMC the contacts could be removed with the end of the casing with a couple of screws once the big cables have been disconnected. Can't remember the details but no soldering needed.
  13. Could be the contacts in the starter solenoid, with a fully charged battery just giving enough kick to overcome the corrosion. Take the solenoid off if possible (more than one model of starter used I think) and give the contacts a clean with a small file (a nail file is good enough).
  14. I was dragged up within 100 m of Fulham FC. In those days the site of the luxury flats immediately upstream was used by lighters which tied up on a well-dredged wharf. (The warehouses burned down in around 1972, always wondered what started the fire). Indeed, the whole stretch upstream almost to Hammersmith Bridge was used as wharves.
  15. Yes, I used to have a couple of tons of it in my lab that had been recovered from Scapa Flow. Underneath we found a very well pressed copy of "Top Busters", which may not be relevant here. 😮
  16. Thanks Tracy D! I could doubtless find it easily enough, but possibly not quickly if panicking!
  17. Where is the stop level (or is the answer "it depends")?
  18. Zinnser paints are generally very good. I've used them in the house on a wall prone to damp and on the gunwhales (the latter water based black paint but dead easy to touch up if damaged, and it seems to last).
  19. Dry dock, welding and patching at both ends (a few m^2), blacking.
  20. We've just spent €8,500 on docking our shared boat which is a fair bit more than last time (six years ago, but delayed due to plague problems). I guess we budget at £ 1- 2,000 a year for docking.
  21. Chances are high that she'll need some overplating and welding, but that's normal for a boat of that age and needs to be factored in to your budget. Our barge is a similar age and there's always some hull work needed at docking. The engine at 44 kW might be a bit low powered but unless you're planning on taking it up the Rhine it should cope with the Thames (looks like the Thames from the pictures, but can't place where near Oxford unless it's an assortment of places - some of the pictures look like Oxford Cruisers at Eynsham).
  22. Just found this resurrected thread. Firefly was converted to run on an air-cooled Lister about twenty-five years ago. We viewed her when she was up for sale in around 1997 (Wilton marina?), a clean but very basic fit-out at what seemed a reasonable price (around £25k if I recall right).
  23. Our domestic washer was jammed with a piece of curved steel about the size of one of the wife's undertits. Buggered the pump completely.
  24. Have you got any time-expired fire extinguishers?
