Everything posted by Tom and Bex
This is the exact problem we're having, and already resigned myself to an expensive additional cost at next blacking. Ours will stop leaking with use of greaser, but will always leak after running, regardless of stern gland adjustment. Haven't got round to examining ours yet so studying replies carefully. What I can say is ours has definitely been repacked correctly as done it myself. Engine alignment should be fine as well as it uses aqua drive, but there is some slight side to side play at the prop end, so suspect the whole lot will need replacement😥
I use very similar by modifying my existing vag-com lead (for diagnostic use on VW group cars). Got the details from a Russian Internet forum translated by Google translate! Worked OK with 2 different era eberspacher heaters, not tried with webasto.
Tipton Lock (Factory Lock No3) closed for recovery work
Tom and Bex replied to Alan de Enfield's topic in General Boating
Is that still the case now? And are they usually locked? Haven't been that way for a while, but most of the other BCN flights I've done recently have lost their anti-vandal locks, and the few remaining ones either don't work, or are not locked by boaters. Certainly very few locks now seem to have a full working set at both top and bottom. -
Shower waste water pump (cheap item on ebay)
Tom and Bex replied to Karen Lea Rainey's topic in Boat Building & Maintenance
Having tried an alternative (already fitted on boat, but soon changed!) I'd never have anything other than Whale Gulper ever again. (Unless you really enjoy cleaning filters out every week🤣) -
10x the price I paid! Think I'll stick to my cheap Chinese heaters and take a chance!
One of ours is installed in an open cupboard in the lounge, but diesel tank installed in outside locker. Would be wary about having diesel tank inside due to smell and possible spillage when topping up, but nothing to stop you having it in your utility room. Just ensure the exhaust is well lagged due to heat, and obviously exhaust exits through hull (and don't use supplied silencer!).
I've fitted 2 of these heaters to our current boat, and I can assure @Alan de Enfield that the total cost of both heaters and extra fittings was considerably less than the cost of a single eberspacher or webasto heater on its own! BSS are currently reviewing requirements for these heaters, and will currently allow installation using supplied fittings, tank, pipes etc (see attached pdf from them). Our rear heater was installed in engine bay, and takes diesel from existing eberspacher feed from main tank. It was installed without silencer, and pipework is copper brake pipe throughout, with short iso compliant rubber hoses for connecting up, as per standard marine kits with the expensive heaters. Brake pipe was flared using automotive flaring tool. Combustion air intake is from within engine compartment (standard cruiser stern). I use this heater for heating back deck (ideal for drying laundry with pram hood up!) and rear bedroom/dining room. Don't find it particularly noisy without silencer either inside or outside the boat. Our front heater is installed using supplied tank, and supplied hose from tank to pump, both fitted in outside front locker. I then used copper brake pipe to bring the feed inside to the heater which is installed in a front cupboard next to the door. For this heater I used a marine silencer. Combustion air is drawn from near water tank, and heater air from behind paneling (due to space!). Both heaters have recently passed the BSS, and it was an examiner that pointed me to the current BSS guidance on diesel heaters. Front heater is installed with the exhaust outlet noticeably higher than the heater with no problems. Both have the exhaust lagged, and beware the exhaust gets VERY hot during use. Can't see the need for an insulated skin fitting for a steel boat though, and both ours use a standard brass skin fitting. It's often cheaper to buy the all-in-one heater unless you need the separate tank, and the heaters and control panel inside the casing are identical. I'd suggest shortening supplied power cables and replacing with thicker cables direct to battery (via fuse). I just about got away with using supplied cabling, but only due to the higher voltage of lithiums. Both heaters cost less than £80ea, and I just went for cheapest I could find on ebay with UK stock. Rear heater now been in use for 2 years, and front for 1 year, both have been 100% reliable during that time. Marine silencer (£37.50) and mounting bracket (£15) for front heater came from southernmarineproducts.uk which is considerably cheaper than i could find elsewhere, and seem very sturdy and well made. Happy to answer any further questions on our setup. I'd strongly advise CO and smoke alarms for peace of mind. BSS guidance pdf attached. ETA - Fuel pump for rear heater is mounted at deck height (12" above top of tank) and has to draw fuel through around 2m of copper pipe. Although standard advice is to mount pump below tank, this setup hasn't caused any problem in 2 years, and heater actually primes much easier and faster than eberspacher that is mounted close to, and below diesel tank. bss-interim-position-on-diesel-appliance-fuel-supply-arrangements-dec-2021-final-v10-modified-on-211208.pdf
Water Explorer - to shut down at end of 2022
Tom and Bex replied to stuart's topic in Waterways News & Press
Sad to here about this, but understand your reasons. Found it really useful over the years to quickly and easily record journeys and look back at old trips and timings. Particularly liked the windows app, and having it running stopped all the questions from crew as to how far until the next lock! Is there a way for members to download their old journey data? I think I've got the GPS log of most the recent stuff, but not the older ones. -
Good to hear you've had no problems with yours. Maybe I'll try a new one and keep a close eye on it, no way of knowing how a used one has been treated previously. After all the first one lasted 3.5 years, and failure was almost certainly due to poor external connection/cable. I'd forgotten about that so something I'll check. Didn't think it would make much difference though if not switching under load? Can't say for certain it's never stuck on, but certainly shouldn't have, and working as expected now. It's controlled by a proprietary sealed unit sold specifically for this purpose: https://www.solar4rvs.com.au/rec-bi-stable-relay-driver-bslrd-for-bottom-end-sw
Thanks for idea about relay coil, but only driven when it's switched, and only using short pulses as per spec. Relay operated for some time prior to failure today so still remains a mystery. Prior to dismantling, relay could still be heard to click positively when switched on or off. Edited to add: Have just checked coil drive connector, and no voltage on terminals until switching, when just a short pulse occurs as expected.
Has anyone else that uses the tyco BDS-A bi-stable relay had problems with it? I've just had a second one fail open circuit (with evidence of overheating). Only used on the charging side (load side uses a BEP motorised battery switch) and never been switched under load (to my knowledge). Max charging current is around 160a (although we rarely see more than 140a) so it shouldn't be overloaded. I think @nicknorman uses one and can charge at a much high rate than i can! Annoyingly both failures have resulted in blown alternator😡 I put the first failure down to poor connection as clear evidence of the connection post and cable overheating with corrosion to the cable. This was probably my fault for reusing old cable and crimped end, and in fairness there were warning signs for several weeks before it failed. All cable replaced with new well made crimps when the relay replaced 6 months ago. No problems until today with sudden failure of all charging when cruising. No prior warning at all, and evidence points to relay itself rather than cable connections. Do I replace with another used one? Or bite the bullet and buy new? Or forget the tyco completely and use something else? Evidence of overheating to internal relay contacts, but no evidence of significant wear, pitting, or corrosion on dismantling.
Paste link into this site: https://12ft.io/ Doesn't always work but can be useful when it does. Gets round the paywall on lots of common sites.
Cards are so yesterday - can't remember the last time I used card or cash for anything! Contactless on phone all day long. Only 1 thing to carry then and does everything. Anyone that won't take card usually get paid via PayPal or bank transfer. BCNS had the last 3 cheques I wrote, and that was all for BCN Challenge entries before Richard and Sue took up organising it and accepting modern payments!
My thoughts are turning to the black stuff
Tom and Bex replied to rusty69's topic in General Boating
We've just bought up the last excel our supplier had at last winters price of £13.50 per 25kg bag. Price going up from next delivery to £16 per bag, and increasing again to £17 in August😱 Price usually drops in summer - dread to think how much it could go up to next winter. -
At Knowle you can easily walk round both sides and we usually find it easier to work the off side. Actually involves slightly less walking than the towpath side as no disused locks to walk round (unless you've also got a buggy, then the towpath is definitely easier!). Generally (despite my moaning about them) we generally find Knowle locks in good condition and rarely have a paddle out, so quite surprised to hear about this stoppage.
Practical advice for dealing with the heat onboard
Tom and Bex replied to DShK's topic in General Boating
Sitting or lying on the floor can help - particularly if (as on most boats) it's uninsulated. -
Down to Salford Junction, up Perry Barr, Ryders Green, and Spon Lane, then down Smethwick and into Birmingham via the loops🤣🤣🤣 (and yes we have done that just for fun, and not during the BCN Challenge!)
Or depending how much time the OP has, they could do Perry Barr and Ryders Green... Same here - some people have an aversion to sharing rings (or bollards!) even in busy places. You should have seen the look we got coming into this gap, they were adamant we wouldn't fit (didn't touch the boat at either end)🤣
We've had various small stoves in different houses and boats, but so far nothing comes close to being as controllable, easy to use, easy to light, easy to keep in for 24hrs, and with such good ash management as the morso squirrel. Also designed for burning wood or coal, with finely adjustable top and bottom air vents, and widespread parts availability. As others say, you're bound to hear about more problems with them than other stoves as they're much more common. That's not to say they're without faults though - cleaning behind the back boiler being one (although a simple mod to the blanking plate helps). The main reason I think they crack is poor installation (eg not being installed level, too rigid a flue connection etc). High temp silicone should be used to seal flue joint at top of fire and roof collar, not fire cement. Also screws not being over tightened. If the stove is otherwise solid and secure, and the cracks are only small and not structural, I might be tempted to smear high temp silicone over them and monitor closely for further deterioration, but only if I had working CO alarms. Would very much depend on where the cracks are, and how big they were though.
If it wasn't for Knowle locks, I prefer heading the GU way. As others have said, not sure I'd choose to go via Star City, but then you could say what's the point of any out and back trip! Personally I find it much more interesting than the Stratford and W&B route. The bit through Catherine de Barnes is definitely much improved following the dredging, certainly no worse than parts of the Stratford. Moorings as mentioned already, plus we've moored on the moorings above Ashted locks a few times with no problems. Easy access from Aston junction as well if it's getting late when you get there and don't fancy farmer's bridge until the morning. If you take the direct route via Ashted locks instead, you could take a short detour to Typhoo Basin. Definitely advise avoiding mooring between Worcester bar and the mailbox if it's a weekend, but just around the corner is fine. Mainline outside the arena on the same side as the lego giraffe can be noisy and rowdy too, (particularly if there's football being shown on the big screen at The Distillery!) but the opposite side is much quieter, as is the mooring rings out beyond Vincent Street Bridge.
Sorry to hear that. Get well soon Tree Monkey. All the usual crew we have on Tatty Lucy also send their best wishes for a speedy recovery.
If I'd thought we'd be that high up, I'd have taken more care with my answers! We got 2 wrong, through silly mistakes, and missed the Withymoor one.
Wow! Didn't expect 2nd! Was hoping for top 5, but never expected that high. Congratulations to Vulpes, overtaking you on the Walsall didn't help us in the end though🤣 This year we took a different approach to usual for us, and chose a route with less locks, and no long flights. There's only so many locks you can do at once with an 8mth old and 6 year old before they get bored🤣 Surprisingly Bea, our 8mth old was much more tolerant than Lily! That's 4th, 3rd, and now 2nd in our last 3 Challenges - watch out next year!!! Huge thanks to the organisers for putting in the work to organise and run this event, particularly with the last minute problems around Netherton and the Daw End closures. Thanks also to Withymoor Island for putting on such a warm welcome. Going to be a hard ending to beat!
Whichever you decide to use, be aware that some (all?) of the Sikflex range in screwfix etc has changed to a "low odour & solvent free" formulation that doesn't seem quite as good. Suspect the other brands may have followed suit. I only noticed this as the info has changed and it now states "apply in dry conditions only" and I was specifically looking for something to use as a temporary repair in a damp location. I'm 99% certain it was previously sold as suitable to apply in wet conditions, as was most of the other professional pu sealants.
How many and what size panels are people fitting for 1400w of solar? That seems an awful lot of roof space used. What about roof use during cruising? Pole and plank storage? We've only got 500w solar at present, but considering upgrading. Part of our problem is our mooring is shaded by trees until mid to late morning. As to solar thermal, we use the 2nd option, a direct system. Flat panel mounted on the roof, and using the direct system will heat the calorifier. It's plumbed in as your diagram, the main difference being that it uses a 12v differential controller to switch the pump instead of powering it direct from a solar panel. This means it doesn't waste the hot water if you have a tank of hot water after cruising etc. Fairly cheap and simple to set up, biggest problem was routing pipes up to the roof. Looks in diagram as though hot water drawn from the taps would bypass the tank, but this doesn't really happen in practice due to length of 10mm pipe pump etc adding resistance to flow compared to just straight from the top of calorifier. Given a preference, I'd go with heating water via extra coil, but we don't have that option. Biggest downside to direct system is the need to drain down in winter (indirect systems can be filled with antifreeze). I do agree things have changed a lot in recent years, even since we bought our current boat 5 years ago. Not sure the extra effort to install solar thermal is worth it now over having extra solar PV. Price drop of pv panels, combined with lithium batteries really does seem to have changed the balance and is a real game changer for off grid use.
