Everything posted by philjw
If you can get in there, Costco sell Prestone concentrate in 5 litres.
And that was meant to start a car?
I could, in theory, but they are usually located in isolated locations, no one is going to hire a taxi to visit a recycling centre, it does not m sense Depending how much the battery weighs it could make sense to take it to a scrap metal merchant. The last set of leisure batteries (4 x115 Ah) paid out nearly £50 in Daventry. If you do this take photo ID and your bank details. Or maybe a local scrap merchant could collect from you?
tackle discoloration in wood.....
philjw replied to robtheplod's topic in Boat Building & Maintenance
You can buy oxalic acid from letonkinoisvarnish.co.uk They call it Traditional Wood Cleaner -
It's possible to hire Tirfor winches https://www.nationaltoolhireshops.co.uk/category/tirfor-winch-hire/ Don't know if the cables are long enough to reach the piling on the far side or a tree
I bought 49 bags of Brazier on line from Home Bargains which works out at £5.92 for 10Kg delivered . The fuel itself is not as good as in previous years. The lumps are bigger and harder to light. https://www.homebargains.co.uk/products/25412-pallet-of-49-bags-brazier-multipurpose-smokeless-fuel-including-home-delivery.aspx
taking thetford toilet out of the boat with cassette jammed inside..
philjw replied to aristorias's topic in Boat Equipment
Did the old cassette have wheels and a handle like the new design do? I have the old style without either. I've wondered before if they are interchangeable. It looks like they are not. Perhaps you could remove the handle. Photo doesn't clearly show how it is fixed to the cassette. -
Point of order. Voltage is measured in Volts, and current in Amps, Yes, I should have said current of course . Your thoughts re diode(s) echo what I was afraid of. I believe that the top limit on the diode test is 800mV. I'll be heading towards Birmingham in a couple of days from Stratford upon Avon and I think that a company called Rotating Electrics in Stetchford is within striking distance of the GU so I will try them first. Has anyone any experience of them? Thanks for the prompt replies. Phil
Hi All, I'm having some charging issues. Measuring the charge voltage first thing in the morning my Uni-T UT203 shows a current of around 30 Amps from an Iskra 11.203.918 alternator rated at 80A fitted on a Lombardini LDW1404 engine. The alternator has done about 2 years service. This is going into a battery bank which was originally 4 X 115 Ah batteries about 5 years ago. The alternator achieves 14 + volts. The rev counter has also stopped working. What do you all think? I have tested the alternator using the diode setting on the UT 203 and I get readings of 0.885 with the red lead on the alternator casing and no reading when reversed. What other tests should I be doing? I would have thought that the battery bank is sufficiently discharged to call for more than 30A first thing. I don't have any fixed battery monitoring kit. I do have the voltage reading from the Victron app from the solar panel controller which with no load this morning in the dark showed about 12.3V so around 60% charged. I'm looking at replacing the batteries before long and I'd like to be sure that I can keep them properly charged. Thanks, Phil
Or here? https://www.stoves-spares.co.uk/cooker-oven/050517101/catalogue.pl?path=1053541&model_ref=2837699&page=3 Not cheap. You can always look at the caravan world who use the same kit
https://www.alamy.com/stock-photo-people-on-a-canal-barge-on-a-rainy-day-travelling-along-the-shropshire-138059210.html?pv=1&stamp=2&imageid=7C85BA73-E745-42EC-B0AE-90ECBABD2F43&p=355664&n=0&orientation=0&pn=1&searchtype=0&IsFromSearch=1&srch=foo%3dbar%26st%3d0%26pn%3d1%26ps%3d100%26sortby%3d2%26resultview%3dsortbyPopular%26npgs%3d0%26qt%3dbarge%20rudder%26qt_raw%3dbarge%20rudder%26lic%3d3%26mr%3d0%26pr%3d0%26ot%3d0%26creative%3d%26ag%3d0%26hc%3d0%26pc%3d%26blackwhite%3d%26cutout%3d%26tbar%3d1%26et%3d0x000000000000000000000%26vp%3d0%26loc%3d0%26imgt%3d0%26dtfr%3d%26dtto%3d%26size%3d0xFF%26archive%3d1%26groupid%3d%26pseudoid%3d%26a%3d%26cdid%3d%26cdsrt%3d%26name%3d%26qn%3d%26apalib%3d%26apalic%3d%26lightbox%3d%26gname%3d%26gtype%3d%26xstx%3d0%26simid%3d%26saveQry%3d%26editorial%3d1%26nu%3d%26t%3d%26edoptin%3d%26customgeoip%3d%26cap%3d1%26cbstore%3d1%26vd%3d0%26lb%3d%26fi%3d2%26edrf%3d%26ispremium%3d1%26flip%3d0%26pl%3d Imagine this one but with a plate covering the gap where the rudder stock passes through.
Two complete tanks side by side with a gap between them, Rudder stock between the two. Both tanks watertight. A common to both top to the tanks with a tube just bigger than the rudder stock bolted (welded?) to the top plate through which the rudder stock passes.
I had a cruiser stern boat built by Arcrite in 1983. As I recall there was a removeable plate that exposed the rudder stock which was not in a tube. So there would have been two tanks with a balance tube between them. Maybe the top section was common with a short rudder tube. The design of the Arcrite boats was pretty much a straight copy of the Harborough hull. I believe that the two guys who owned Arcrite had previously worked for Harborough Boats.
Where is the boat?
I have a wooden metre rule. No need for any additional markings, just measure the increase in level for a known volume of fuel added once to learn how many litres per cm or inch.
I'm not sure what those measurements would be. ID? Just measured the the plug on the mains transformer that came with my recently bought 535 and the OD is 5.5mm. I can't accurately measure the ID but it is around 2.5mm. 5.5mm OD x 2.5mm ID is a plug size that exists. You do get a 230V AC to 12V DC converter in the box if you buy new anyway.
Those catches are the same as I had on a previous boat. The windows were from Channelglaze. Give them a try: http://www.channelglaze.com/accessories/fixtures-fittings/ I seem to remember that the channelglaze logo was on the windows.
Thanks for the replies. I think I should leave well alone. I haven't changed the defaults other than to change the passwords so should still be set to auto.
I've bitten the bullet and bought the Poynting antenna and Huawei router which has been recommend on here. It came with 5m cables. If I want to permanently fix the antenna it would mean cutting off the existing connections, shortening the cables and replacing the connections with new. Can anybody tell me what the connections are called and is it possible to fit them with no special kit? Where would be the best place to source the replacement fittings? Might it be possible to wire the router to a socket that the aerial could plug into? One other question, does it matter which way round the antenna cables are fitted to the router? I've experimented little and can't see a difference in performance. Thanks Phil
I find that bleach gets it off
So that is an inverter charger not a generator but it has a pass through capability. As most shore supplies are 16 Amps it looks like it will be fine as a charger but since the pass through can be 25Amps you would need to be careful what loads you have running at the same time. I don't know if this model could use battery power via the inverter to meet any shorrtfall. Specifications battery charger Input voltage range 170-280 V Max. input current 13 A (adjustable) Max. charge current at 40 °C / 104 °F 60 A at 28.5 V (configurable) Battery temperature sensor yes, included Battery voltage sense automatic compensation Specifications transfer system AC input 25 A (switched) AC output 38 A AC input fuse yes Transfer speed 10 ms Transfer voltage range wide: 90–280 V / narrow: 170–280 V Transfer frequency range 40-65 Hz
After Ron's Rottweiler I think.
Driftgate 2000 XAlt and XSplit information please.
philjw replied to Tracy D'arth's topic in Boat Equipment
You have a PM. Phil- 6 replies
- driftgate
- alternator controller
(and 1 more)
Tagged with:
