shaktjor
Posts posted by shaktjor
Hi RLWP
It is drag but not a slight 1.
With the gearbox in neutral so the clutch operating arms are fully disengaged we can turn the prop shaft with a pair of stilsons eg 600 mm long but it is hard.
With this much drag it looks like the prop shaft is going at full speed.
We believe the plates are distorted and are working out how to do a clutch replacement without rmovig the reversing and redfuction gearboxes.
Regards
Nick
17 hours ago, Tony Brooks said:
Pleased to be of use.
General principles, any chance the splines on the plates have jittered steps in the splined shaft so they can't move apart so easily?
Thanks Tony.
1 hour ago, RLWP said:The forward clutch doesn't fail in many way. It could be stuck (in which case the engine stalls when you select reverse), It could have lost all the teeth on the fibre plates (in which case you'd have no forward), it can drag, or it can break and the broken parts wedge the plates in forward
Have you got fully engaged forward, or is it just dragging? I suspect drag as you can get reverse.
If it is dragging, chances are the fibre plates have distorted. The solution is to replace them
Richard
Hi Tony. It is a multiplate clutch.
By the way, thanks for the course you used to run in Stafford. My son came in 2008 or 2009 and now has a marine and car mech and elec business in Queensland and was inspired by you.
Regards
Nick
We have an old tug for canal restoration with a Lister HA3 none hydraulic reversing gearbox
It has a Blackstone reversing gearbox.
The first problem was it would not drive in reverse. We adjusted the brake band and that was fixed.
Now the gearbox is always driving forward. The clutch is disengaged ie there is a clear gap between the 2 clutch arms and the actuator ring. Even in neutral the prop is in forward.
This means , for some reason the clutch is not disengaging.
I read that this gearbox shares oil with the engine and there is no dipstick in the reversing gearbox.Ideas of a cause and details on how to get the cluch assembly woul dbe very greatfull received.]
Thanks
Nick
Lister HA3 fitted with mechanical Blackstone reversing gearbox.
in Boat Equipment
Hi Tony.
I think I wrote it badly. We need to inspct and probaly change the clutch plates. The reversing gearbox has mounts that are effectively the rear engine mounts. The rear of the reversing gearbox has the reduction box bolted to it. The rear bearing of the shaft coming out of the reversing gearbox is in the reduction box. So it's complex to change the clutch plates.
Regards
Nick
