it looks straight forward with nothing in the way but the engine needs supporting as mounts need to come off and i think the engine needs raising 10mm for the alignment of shaft.. i have gayton marina to do the work if there not to pricey... wish i was younger then i would be having a go myself...
i think im going to go for a new prm90 as thats all i can afford... how long or much do you think it will cost for fitting so i know if im getting stung or not... thanks again
its sounding like i should just go for the prm90... from what ive read the engine needs to be raised 10mm on the mounts to fit it so will have to check if its possible on mine... i dont think ive read a good thing about hurth boxes.... mind you alot of it seems to be reconditioned boxes giving problems, maybe just inferior parts compared to original bits...
thats brilliant .... i think i will check on the prices for a prm90 and get a quote to fit as it will probably need fettling... is a cone box smoother to operate as mine does clunk when going into reverse and used to when going into forward until clutch started to slip...
thankyou richard for finding that out for me... its to fit on my nanni n21 (kubota 3 pot).... i think the prm90 is looking best bet .. i cant believe how rubbish the hurth boxes are and the price of spares.. thanks again...
thankyou for the links... just wondering if anyone has done the conversion on here? ive found a used hurth box for not alot of money so might risk it and if no joy then a new box it is...
the gearbox on my little springer 23ft i think is on its last legs as forward gear is slipping badly... its a hurth 50 mechanical box from what i can tell.. does anyone know where i can get it reconditioned or buy a replacement... will the prm90 box be a direct fit? any advice would be great....
thanks everyone for all your advice... i didnt even realise you could get electronic oil pressure gauges, do they just connect to the sensor for the oil light... will be so much easier than trying to fit pipe and sender etc....
fingers crossed i have that... cheers... any idea on an oil pressure gauge? i brought a set of 3 gauges and i know i can fit the water temp and volt gauge and just wondered if i could plumb in the oil one?
hi all... im building a new instrument panel for my boat and wondered how hard it would be to add a rev counter and oil pressure gauge?
i have a nanni 3.21 engine with just basic water temp gauge at the moment... any advice would be great...
hi yes its a kubota 3.21 ... im not sure if it is the heater plug or not yet... but its the same problem the previous owner had so just assuming it could be the same cause but i will check the strap aswell.... there are now 2 isolater switches for the batterys... not done by me though... was like it when i brought it....
thats brilliant.... totally understand now.... thanks again for explaining... is 10 years good for plugs as im gathering thats when the the old owner changed them...
bit of a longshot but i am the current owner of wee jenny and now have exactley the same problem... ive read through this thread but dont quite understand how the problem was solved... anyone able to explain for me? thanks
spotted these on ebay just incase anyone was looking for cheap heating...
https://www.ebay.co.uk/itm/Narrowboat-Eberspacher-D5WZ-Diesel-water-heater-Complete-unit/332787153201?hash=item4d7ba8f931:g:GRQAAOSwV01biZKz
