thanks for the help, It is a new shower with the same problem as the old one. i had previously blown through the pipes and checked all gauze in the shower. I will remove and follow the processes again.
the pump kicks in as supposed to but never gets back to original pressure to when the tap is opened at the start.
Hi all,
We have had some issues with our water pump/ morco boiler/ shower in producing enough pressure to have a shower comfortably. the pressure is at around 2bar if i remember correctly I dont know the flow rate of the pump the accumulator is set at 1 bar as I was advised to set the accumulator at half the pressure of the pump. the issue in the shower is that when the temp is set to 38 water flows for amater of seconds and then the only way to get water from the shower is to have the temperature at full whack. I have afeeling that a stronger pump would help but is there anything I am missing?
Thanks
