Hi all
brand new boater here. I moved onto my first liveaboard just a few days ago. She was sold as needing a bit of headlining work but otherwise good to go. Unfortunately I’m finding that the closer I look the worse it gets. I was beginning to accept that I will just have to gradually chip away at all the work while still living onboard, until I found the rot. The rot extends down the right hand side rear of the boat, and appears to come from an unchecked leak in the central cabin.
My question is basically, once I hopefully fix the leak and remove the rot, will she still be sound? The rot is in wood that meets the hull, so at the bottom of the furnishings, the wardrobe and the storage/ seats. But also in the wooden division between the central and stern cabin - and this I am most worried about in case it is structural.
My dawncraft is a central cockpit cabin, and the previous owner has done a (what I now realise is shoddy) diy wooden box over the central cabin
Does anyone have any advice? Please consider that this is also now my home - I trusted the seller, didn’t know where to look properly, and I am certainly now learning from my mistake.
pictured are the wall in question and what I can see of the rot- cant get a photo of the extent as i cant remove the floor without dismantling everything at the moment. The other vertical wooden fittings look similar at the bottom, if not quite as bad
thanks everyone
