Everything posted by HenryFreeman
Land Slip - Easenhall Cutting, Brinklow, Oxford Canal
HenryFreeman replied to RAB's topic in Stoppages
My journey south was going to take me via the Coventry canal then Oxford Canal (Northern Section). Obviously I can't do this now so can anyone recommend something of a diversion? Cheers! -
Thanks for that heads up, I won't be going that way then! So not the Macclesfield - Trent and Mersey, Coventry Canal, Grand Union. The Macclesfield will have to wait for another day. Cheers!
Yeah, good point. Coming from Barnoldswick -> Chorley -> Wigan and then going onto the Macclesfield and onwards south via Oxford Canal -> Braunston -> Grand Union.
Ah perfect, thank you! Cheers! Big help!
Thanks for this! So that brings up a new question about how/who/where/when to pay for a visitor mooring on the Bridgewater! How/who/where/when do I pay for a mooring? Thanks for the suggestions! I've a 55' narrowboat so may/may not be a squeeze in that spot. It's just going to be for at most 5 days/a week. I'll look up that marina and see what they have. I don't mind paying £10 a night! Thanks very much!
Hey all, Will be heading to Manchester over the next few weekends as part of my cruise down south. I'm wondering if anyone can recommend any moorings which might be safe(ish) to leave a boat for a few days in-between cruising days? I seem to recall reading Manchester isn't the best place to leave a boat but would welcome any opinions. Thanks!
Batteries, inverters, power bank questions
HenryFreeman replied to HenryFreeman's topic in Boat Equipment
Cheers! There is an idea too. -
Will do some reading! Might be a cheaper approach. Cheers! -
Yeah, not getting that one! I'm going for the cheaper one, the AC200 (About £1200). I suppose for the expensive one it's built to be expanded - you can add up to 4 additional battery packs to give you 12000 watt hours. But yes, pricey. -
Thanks all for your advice! Just to answer a few questions.. I've got a portable generator (Kipor 2600) and a Victron battery charger that I use to keep the batteries charged rather than using the engine. So am basically able to charge the battery bank whenever it needs charging. I've also just remembered I've got a small 400w inverter that is used for powering my Morco water heater which might well suffice for charging the Bluetti. The Bluetti is a LiFePO4 power station/battery with a built in 2000w inverter and can power 240v appliances, usb, 12v etc. It's a handy unit (not that I have one yet but have been doing a lot of reading up on them) and possibly a bit more flexible than a traditional lead acid battery bank. Plus you can add additional battery packs to extend it to 8000+ watt hours. -
Hey all, Looking for some advice. So I've had the same set of lead acid batteries for about 7 years now and they've basically given up the ghost. And while my boat was in the boat yard getting painted, the inverter went arse up due to being filled with sandblasting sand. So between the two, it's got me thinking about my electrics. Honestly, I don't use a lot of electrical items on the boat outside the lights, fridge, pump for shower, pump for water, bilge pump. Anything like running a laptop, TV etc. I just run off the built in battery (laptop/phone) and the TV is rarely turned on. In fact, I'm pretty sure it's also full of sand and knackered. So I'm beginning to wonder if replacing all the 4 lead acid domestic batteries and getting another inverter would be a waste of money? What I'm wondering is how few domestic batteries I can get away with installing to run the pumps, lights and fridge. 1 would be ideal but I suspect that might not be possible. Lights and pumps fine - fridge as well? Possibly not. I've also got 600w of solar on the roof. The fridge is one of those Inlander 12v conversions. For the money I'd spend on 4 batteries and another inverter, I could get one or two domestic batteries and one of those big Bluetti power stations (https://bluettipower.co.uk/products/bluetti-ac200max) for running any 240v stuff on the rare occasion 240v stuff gets run. Wondered if anyone has any advice/suggestions? What is a realistic minimum based on the above? Just thinking, I'd probably need an inverter of some kind to charge up the Bluetti. But maybe just a cheap and cheerful one rather than a fancy Victron one. Cheers!
You can find many of them right here. People are lazy - they'll just blame an entire demographic rather than making the effort to understand the majority of people in whatever group get on with their own business quietly and contently.
Going to be heading London-wards from around the Skipton area over the next few months. No massive rush but want to go fairly direct rather than go out of my way. While time isn't of the essence, I want to make it easy for myself. Looking at opencanal map there's plenty of routes to head down south. I can continue following L&L (which I'd probably rather do and see new pastures rather than go back on myself towards Leeds) and from there either via Liverpool, via Manchester and then from there there's a number of ways to continue. Any recommendations? Part of me wouldn't mind going through Birmingham so would definitely consider that route. Over to you lot! Thanks
This is 25 quid from BCMW. Who is making one of these in an hour to let them still make a profit? Children, I suspect. And not children from this isle.
Yeah, if I was getting some work done I'd expect the quote to be what I was going to pay, none of this "plus VAT" nonsense. I'm not a business, what makes you assume I'm VAT registered? I'm a bloke with a boat.
I think the vast majority are most likely than not the vocal/inconsiderate minority. Out of all the boaters on the cut, you think more of them are inconsiderate than not? Perhaps I'm more of a half glass full type, but I'd say you're probably wrong in this case. Most people get on with things quietly and considerately.
Hmm.. sounds a bit shoddy to me, to be honest. Although if you take a car to a garage to get repairs, they'll often quote a price and then under their breath say "there'll be VAT on top of that, of course".
Incredibly, my domestic batteries are still going - have had the current boat since 2017. I've got five fairly generic branded domestic batteries which I suspect haven't been treated as well as they possibly could have done and yet they still appear to hold charge. I'm mostly expecting them to give up the ghost in the next 12 months or so but who knows, perhaps they'll keep going. To be fair with those batteries, the most constant use for them is lights, pumps and fridge - I don't really tend to use them for much else (have various battery/powerbanks for phones, laptop etc.). And 700w of solar keeps them topped up.
That you would take enjoyment from someone's misfortune speaks volumes about the kind of person you are. I hope @truckcab79 is successful in their project and even if they aren't then they enjoy the time spent on it. I suspect he'll be plenty successful and I look forward to seeing the end result. Being as you don't seem to add any value to the forum, I reckon you'll be going on my ignore list. Don't really need to be reading any further nastiness from you.
Why does it bother you what other people choose to spend their money on? If he buys a money pit, then he buys a money pit. I don't think anything you've posted in relation to @truckcab79's plans have been in any way, shape or form help or assistance. You're just sniggering from the sidelines. Why are you bothering to comment? Is your life that empty?
Hey Siri! What is a strawman argument? A straw man fallacy (sometimes written as strawman) is the informal fallacy of refuting an argument different from the one actually under discussion, while not recognizing or acknowledging the distinction. An everyday conversation: Alice: Taking a shower is beneficial. Bob: But hot water may damage your skin. Bob attacked a non-existing argument: "Taking a hot shower is beneficial." Because such an argument is false, Alice might start believing that she is wrong because what Bob said was clearly true. Her actual argument, however, was not disproved, because she did not say anything about the temperature. Thanks Siri!
