Hello all.
So I've got a Webastow evo top, installed on a Collingwood widebeam. Boat and Webastow are 3 years old.
I've had constant issues with the heater. In the 3 years I've replaced the burner, temp sensors and the heat exchanger.
The issue I'm having now is the unit goes through start up fine. Runs for around 30 mins then shuts down. There's a heavy smell of diesel. There is plenty of voltage and fuel.
I did try and balance the radiators and it all ran for two weeks fine. My pressure is 1bar. There is and expansion vessel as its a pressurised system. I had to drill out a broken shader valve on this and added a valve extention which has held.
I cant find any webasto engineers local. I think the issue is the system balancing, possibly air?
Any advice ideas welcome.
I should add, the system crashes, doesn't shut down normally unless I shut it down myself.
