AKULA
Everything posted by AKULA
  1. I e already done it was just interested in who had and what they had done and thought that’s all many thanks all
  2. Has anyone ever combined there morso back boiler to there alde gas central heating. If so any tips plz. Best wishes mike
  3. Greetings all can I add a morso stove boiler in to my alde gas central heating combining the 2. Thanks in advance all
  4. Sorry was thinking I could make from this https://www.ebay.co.uk/ulk/itm/261848236037 Alter is Isuzu 160 or 180 I think
  5. What size busbar amps wise do I need for a 3000 watt inverter to go to my 8xt125 Trojan batts plz so batt to isolator then busbar plz I promise last question
  6. I've some of the but 3 way https://www.ebay.co.uk/ulk/itm/360906148916 I'll have ago in morn cheers all
  7. Start again tablets I'm afraid when I take them they knock me. So pos and neg from inverter are both 90 mm with big lugs one at each end of bank. They take up a lot of room. I can't see how I can connect room wise the alternator cables. Then solar cables all on lugs. That I presume must go to either end of bank Ali g with inverter charger cables end of bank also I was told I have to have a fuse as the first point end of bank am I wrong please I'll apolagise for myself now for those that don't know I've had 2 strokes and get confused and random I don't mean to upset anyone here I apreciate you're help So I thought batt to fuse to bolt with all those connections I thought batt to fuse to bolt with cables running from bolt That's my layout
  8. I've alternator solar inverter hence 90 mm cables batt monitor and to my blue sea trips sure there's somthin else can't think
  9. Physical cable size is 90mm the lugs are m10 that came with the cables big
  10. A bolt to bolt together cables problem I have now is 90mm cable lugs are big. And I can't pile loads of cables either end of the bank So I thought cable of bat to a bolt and so on Best wishes all
  11. Sorry yes it's a 12 volt system I've had a nightmare trying to find a place for 8 t125 Trojans. The only place I could find not in the boat was engine room sitting on the swim. So now I have 8 all in a single file not pairs of 2 opposite each other can I hell find a picture showing 8 in a row 6 volt batts to 12 volts I can't get the mental Picture welcome to the world of 2 strokes. Once again I'd like to thank you all most kindly for you're input I can't stress how thankful I am. Best wishes mike
  12. As ever you're all stars I had it in my head as you all said then the more I thought the worse I got lol once again thank you kindly all
  13. I have 8 X Trojan t125 batts 6 volt 240 ah each one whitch configuration is best in the picture I'm using the victron inverter charger 3000 with 120 amp charger I truly can't sleep for thinkin here is the config photo What would you're good selves do I can't buy experience Best whishes Mike xx I have to fit this at ten in morn using 70 mm cable 4 ft run to inverter
  14. Fertan. Wipe on brush or spray 24hrs later job done
  15. having removed what looked like half of asda one of the ears on my prop is well bent answer to my vibration problem one thing after another latley
  16. Lol try putting it on 3 brand new boats a week
  17. Pmsl you're as bad as me I soent 15 yrs puttin it on in a well known boat builders weren't my job but didn't mind doin it gettin it off is a diff matter
