Farey
About Farey
- Birthday 17/12/1954
Contact Methods
Website URL
http://
Gender
Location
Bristol
Occupation
Software engineer
Boat Name
Strange Attractor
Boat Location
Ventnor Farm Marina
3,216 profile views
Farey's Achievements
Contributor (4/12)
4
Sorry - I should have been clearer. The boat has a Aquadrive fitted, which fixes the shaft alighment. The movement only occurred after removing the Aquadrive so the shaft was then free to be slid in and out. The Volvo Penta seal does not have a water feed; it's one of these: https://www.yachtboatparts.com/volvo-penta-stern-glandspropeller-glands-5291-p.asp. I've greased it regularly, using a drinking straw to get the grease under the seal. I've no idea if the shaft was checked when the seal was replaced, but I would assume so. It was done by Calcutt Boats, who seem to know what they're doing. I wans't aware of the need for descaling; I presume that would require the removal of the seal? I'm not sure if it could be a factor, but last year I took the boat from Bristol to Sharpness, so it was in salt water for a while. What surprised me was how suddenly it happened - nothing one day then a steady drip the next.
Farey started following Milton Keynes Marina Resumes Boat Hire , Prop shaft abrasion , Southam to Leeds, a viable journey? and 7 others
Coming along the Leeds and Liverpool last month I developed a leak from the stern gland - a Volvo Penta rubber seal. The leak was significant - a steady drip amounting to 2 - 3 buckets of water a day and it started quite suddenly. I tried greasing it to no avail, so assumed the stern gland needed replacing - it was last done around 5 years ago. However, when the engineer looked at it he said the cause of the leak was wear on the prop shaft, which he showed me. Moving the prop shaft forward or back an inch or two stopped it. So the boat is waiting to have a new prop shaft fitted. What I'm wondering is what could have caused the prop shaft abrasion? Presumably sand ot grit must have somehow got into the seal, but how?
I've just done the journey in a 60' narrowboat. We went North Oxford, Coventry, Trent and Mersey, Bridgewater and Leeds and Liverpool. We did it in 2 stages, 1 week to Middlewich (5 adults plus a child), then 10 days Middlewich to Leeds with 7 adults on board. We had time to go up the Rufford Branch of the L&L too. Lots of restricted opening times on the L&L, and lots of swing bridges which are prone to breaking down. We got held up once by a broken swing bridge, but only for a few hours. Then I had to leave the boat at Rodley on the edge of Leeds because of a leaking stern gland (prop shaft needs replacing ☹️).
I've moored at Ventnor for 15 years. Nice spot and staff are very friendly. Was owned by Castle Marina for many years, but they recently merged with Aquavista. I've had various jobs done by Calcutt Boats over the years; they're also very friendly and helpful, and I've been happy with the work done.
I need to replace the damaged propeller on my 60' narrowboat. I've exchanged emails with Clements Engineering, who wanted to know details about my boat and engine. I then talked to my local boatyard, who recommended Michigan Marine, who seem to be considerably cheaper. Does anyone have any experience of either?
The excess water seems to be a pure mix of water and antifreeze, so I don't think it's water getting in ... and if the coolant was under presure when the engine was running, how would it? And when it cools, the water level is also high. In response to another comment, I've had the boat for 16 years and never seen this before.
I went out on the boat for 2 weeks in August, and was getting a coolant leak from the radiator cap and had to top up the water daily. At the end of the trip I replaced the cap, drained down the coolant and refilled it with an antifreeze/water mix. The coolant level seemed correct, just below the cap and and between the Max/Min level in the expansion bottle. Then I went out last weekend for 3 days, and at the end of each day the coolant level in the expansion bottle was way over Max, and over the course of 3 days several litres of coolant were ejected into the bilges. At the end of each day I checked the level and removed any excess water to take it down to the Max mark. The engine is a 16 year old Vetus M4.17. I'm baffled as to what's going on?
We just finished a 2 week trip doing the Thames loop. Very busy down the South Oxford, then quiet down the Thames to Limehouse and up the Regents and GU until we got to around Milton Keynes, then it got very busy again, especially going through Braunston.
How long do they typically take to repair a lock beam? I was hoping to go through there this weekend doing the London loop, and may have to change my plans.
Sailaway recommendations (Basic shell) Midlands area
Farey replied to NbJune's topic in General Boating
I'd recommend getting it sprayfoamed inside. I bought a sailaway in 2005. Interior was sprayfoamed with ballast and flooring down. I fitted out myself in a marina with power, working on it 2 - 3 days a week, and it took about 18 months to fit out. -
I enjoyed Ian Grieve's letter on this in the Guardian today: https://www.theguardian.com/food/2021/mar/28/an-unwelcome-sign-of-spring-in-the-air
I'm confused. I took my boat for maintenance in November. Can I retrieve it and take it back to where I normally moor it, if it involves a 100 mile drive and 2 hours cruising?
Thanks for the various answers. To clarify, it is a Volvo Penta cutless bearing, and the prop has 3 blades, and although I don't post very often, I've been a member since 2005.
I discovered some damage to my prop (it's an Axiom, fitted in 2011, but I'm not looking to start another discussion on Axiom props). A small chunk, about 1 x 3 cm, is missing from one blade. I haven't noticed any significant vibration, but am concerned that it may unbalance the prop and put extra strain on the prop shaft and bearing. Any views?
Mooring near Cropredy tomorrow, 4th August
Farey replied to Kendorr's topic in Cruise Diaries & Reports
Here's a few photos showing the situation this morning: https://photos.app.goo.gl/LwzCz7XRQQCGySPs8
