oldade
Occupation
Carpenter
oldade's Achievements
Engager (3/12)
0
Hi A good place to stop after the wigan flight is at the top of Johnsons hillock. Good pub TOP LOCK in won this years localCAMARA best pub prize. Live music thursday night. 48 hour moorings on the off side just through the top lock. Shower block with water tap and pump out on the tow path side. Boat yard just in front of 48 hour morrings. ( they are a nice frendly bunch) An early start from theyer will get you through Burnley. Just after the top lock in Blackburn next to the tow path is an ASDA. After you leave Blackburn at Clayton theyer is a couple of swing bridges that are on the off side you will need your BW key and Windless for these. After that you go over the M65 motorway. ( new concrete bridge) All the locks have the anti vandel locks on so you will need your handcuff key for those. You have nothing to worry about on this strech of canal. Its not as bad as you may have heard. What is you boat called ? So I can keep a look out for you. I hope this helps. ADE
Hi I Have a sterling invertor/charger. It wont won't charge my batterys when conecterd to two gennys I have I It works Ok with the shore power. I think it is an Neutral and earth bonding problem. How do it if I tell if I can bond earth to neutral with out damaging the genny. The genny is one out of cage with 12v dc output 110volts ac as well as 240volts ac The other is a little two stroke jobby. What tests do I need to do to tell if it is safe to connect neutral to earth on the genny. Thanks for any help you can give me. ADE
Hi I have some for sale Two sizes 2 X 4ft by 3ft £20.00 each 2 X 4ft by 5ft £30.00 each All about 9 mm thick You would have to collect from me I live near Blackburn Lanc,s Email 0ldade@btinternet.com Thanks ADE
Hi Weaco CF-35 Portable fridge/frezzer. Bought one a these Ebay no 270274669698 12volt and 240. Silent (When I first connected it my heart sank I thought on no it is broke) its that quite You can set your own temp on the didge display one minute it is a fridge the next it is a freezer. Two big handles so you can use on the bank as a cool box. Extras avalable fixing bracket Insulated cover. I am going to fit mine under the bench seat on a sliding shelf. Danfoss based. Three or four sizes aviable. Shuts down below certain voltage ( dont ask what that is I just know the battery I had it on wasnt flat when it stopped and no it wasnt broke) Charged the battery and it was away again) Take it home put the beer in coolit via 240 at home, take it the boat plug it in to 12 volt (Sorted). Against B**** dear. But much better value because it is so versatile than a standard 12 volt fridge or freezer. I have no connection with the sellar. Or maker. I should be on comishon for this. Thanks ADE
Hi I am going to fit a genny in my narrowboat it will be fitted in front of the engine. On the engine beds so it wont need a fuel pump as the top of the engine will be below the bottom of the rear swim tank. The genny has no fuel fillter fitted at the moment I would like to fit one. My question is if I did fit a fillter would I then need a pump upstream of the fillter to force the fuel through or do we think it would flow through with out a pump? Has anyone tryed it ? I would like to do with out the pump if pos. I am tempted to just try it and see if it will work. What do we think ? Which fillter would we recomend ? Thanks in advance of any help given ADE
Hi If you do the locks last you have two advantages. You are going down the flight (allways easyer) You are going against the river flow on the Seven (you tend to have more control of the boat going against the flow). Thanks ADE
Hi Now that a few garages sell LPG can we refill our bottles at a garage ? Will the garage let us ? Is the gas the same ? Has anyone tryed it ? I have done the maths it is chaper at the mo. 13KG bottle holds 16 Lts If it is 40p per Lt that is £10.40 If are paying around £18.00 that does save us money. I have seen fittings for sale that will fit both the garage pump and the Propane bottle for £25.00 After you have filled 4 gas bottles you will be saving money. You could even do it when you fill the car up. What do we think ?
Hi So If we go with the iso trany we dont need Galv iso then ? Or would it be a good idea to fit both ? Your help would be great THanks ADE
Hi On the subject of ISO tranys. I am right to say that a system with an iso trany will use more AC power due to the trany using juice even when no ac is being used on board as any transformer does ? If I have got this right how much more juice ? How much extra would it cost to run this system as compared to a system with out the ISO trany and an Galvanic iso instead. I am trying to decide which camp to join. Your thoughts / help would be great . Thanks in advance ADE
Hi Finging the sat. I read some where that once you have goodish picture put a damp teatowl ( or simular ) over the dish this cut down the signal so you can fine tune its direction. It works ever time for me. I see maplins are selling hand help sat finders that you can wave around to find the sat has anyone tryed one ? Thanks ADE
Hi Again Its a new build I will be using your gear I hope The engine is a canalstar 30 with 50amp and 110 amp alterntors. 120ah start battery 550 ah domestic 220ah BT batterys. Could you send me a list of what I would need. And the cost as well. I am looking for a top notch system ( not cutting corners ) I have all the battery cables fuses etc I have read all your web site and will be following that. Thanks a lot again ADE
Not chargers or batteries or wiring! Just for a change.
oldade replied to Greybeard's topic in Boat Equipment
I would be tempted to keep it as it is as soon as you cut it you will find you need a longer one. Or could you make get two out of it 2/3 and 1/3 ? Just a thought ( I now I should stop doing that ) ADE -
Hi Question for Gibbo ( again Sorry ) Could I trouble you for a wiring diagram ? I only need the bit with the relays and diodes in. I am sorry if I am being a pain . My email if you want to send it direct. oldade@btinternet.com If it is a lot a work I will understand. Thanks very much again ADE
Hi Thanks to you all for that. A question to Gibbo. You say get a signal from the BT control panel and feed it to the split charge relay that feeds the BT Batterys. I am guessing that you are getting the BT control panel to open the relay to the BT Batterys and saving the fuses that way? I can see how that works because as soon as the BT is turned off the relay will close again and start to topup the BT batterys again. Have I got it right ? Would your three bank gaget be better suited to this set up than you two bank version ? Thanks for everyones help with this it is much clearer now how this all works . Just a thought ( I now I shouldnt do it ) I will need two feeds from the BT control panel wont I because of the two directions ? Can I just join into the cable that goes postitve in each direction ? as that would save opening the BT control panel. Would the current from the BT cable be enough to operate the charge relay and the BT without blowing a fuse or damaging the BT control panel ? Have I got this right ? Thanks very much to you all for this. ADE
Hi Help needed. I am looking for a charging system for my new boat. I will have three battery banks My main question is about how to charge the BT batterys. Which system would work best ? Sterling says run 25mm cables to the BT bank and use one of theyer battery to battery chargers. Whould that be any good ? I see Gibbo does a three bank system which is the one I fancy. But I need to know that it will charge the BT batterys fully given the length of cable ? (57ft) Will the 25mm cables as sterling recomends be big enough to allow the BT batterys to charge fully ? How do the chargers / relays know / mesure the charge in the BT batterys ? I dont understand why I need a battery to battery charger as sterling recomends ? If I just connect the BT batterys direct via a fuse at each end to one of the rear banks what will / won't happen ? Thanks I have learned a lot in a very stort time from all you guys. THANKS again and in advance ADE
