kingofthecut
Everything posted by kingofthecut
  1. I always had plans to convert a Classic to drip feed off the top tank but never got round to it yet.
  2. Agree, its all well and good, just saying the original thread left us to believe otherwise!
  3. If that is the planned times and routes it has no place using the the title 'jam 'ole run'. Autumn boat trip from Braunston to the Jam 'ole maybe more appropriate! I have nothing against them going boating but given the history of the previous re-enactments this isn't one so shouldn't be passed off with the same title surely?! Was quite pissed off when I thought about it this morning when I looked out my window and saw the boat tied up thinking there could be some decent boating to be done but now I look out and it is raining I am not so concerned lol!
  4. Bog in the engine 'ole?! Luxury! We used to dream of a bog in the engine 'ole.
  5. Then they are going for a holiday down the GU for half term as anyone is entitled too but is is not a Jam 'Ole Run then?
  6. Not quite sure I'm seeing the point then? Am still waiting at bottom of Atherstone for Tims call lol! Well, in Polesworth facing the wrong way
  7. See no issue in the slightest and would actually be rather concerned of older materials were used to replace the older materials as how would that save the structure? What I do think though is that if you compare the two pictures it is obvious that the issue was caused by the cyclists as it must have been their sign being drilled into the brickwork that caused the weakness!
  8. Completely agree. If you want to go down the heritage route from 220 years ago then surely all the bricks used at the time were new and not reclaimed! Bridges would have all been smooth and shiney, cuttings would have been scars on the landscape with no trees or growth, locks and weirs would've changed local water flows. The answer therefore is surely replace all the bricks in new to match and not try to match the old!
  9. I see no major issue with this. Why replace old materials with old materials? Surely the idea is to repair so it lasts longer. I would probably write a strongly worded letter to my local MP if they knocked the bridge down and put a flat top steel modern art type in its place but this repair is surely in keeping and will extend the life and safety of the structure. I am failing to see where your issue is?
  10. That is the same argument as not displaying Fellows, Morton & Clayton or GUCCCo on your cabinside as ownership changes. Surely displaying an historical number relevant to the boat is acceptable as is keeping its name and fleet number.
  11. My pet hate is boats stating 'Registered at Watford'!
  12. Not seen Andrew Kendall for a few years, Campion and Guilsborough I kept away from being schooled in Dav!
  13. Some day? He already does! I was regularly late for school on a Monday morning because we'd come straight from the boat at Audlum or Banbury or whereever we happened to have tied up that weekend. Eventually the teachers just nodded and said 'go and sit down'.
  14. Matter of pride to pass as close as possible? Don't be silly! It is/was purely to stay in the deep water. I suppose pride would come into it in some ways as you wouldn't want to move over too far and be seen getting stemmed up!
  15. Weren't Archimedes and Ara an original pairing?
  16. 13-21 is the sat morning to sun evening. The only boats in the re enactments ever to do it in the 7 days as in leaving braunston at 9am saturday and arriving back at 9am sat morning was Greyhound and Australia in 1995 with Ronny Withy, Les Lapworth, Steve Powell and I and even then we were late because by 9am we should have been oiled up ready to start again!
  17. He's normally on the phone begging us to come if numbers are short
  18. Doesn't seem to be much about it then? Usually at least a bit of hype by now.
  19. Back to the point i'm presuming that there isn't one this year then?!
  20. You're the one who was talking about north sea ferries cavitating at a mile depth!
  21. I agree it is and always has and always will be I was just mentioning that I had been told this was technically incorrect, I think it was Ric Young when he came back from University! University education eh., you can't beat it.
  22. The hole is so you can remove the rudder in the water. You tie a rope through it and lift the rudder up and of its cup then drop it down into the water with the rudder stock sliding down its tube then when it has all dissappeared into the cut pull up on the rope and you've removed the rudder. Putting it back on is similar in reverse but you need to drop a line through the hole and tie to the top of the rudder stock to. This is after having removed the rams head of course.
