Hiya, just thought I'd ask on this forum to see wether I'm going about this the right way before I have to possibly call in an electrcian. Firstly let me explain the problem. I'm hooked up to 240v shore line and have a RCB onthe boat which has two circuit breakers in it. Now somehow a fault has developed that is causing the shore post trip to trip out, which as you can imagine, is annoying for my neighbours.
Now i've checked all plug sockets, the extension cable to the shoreline, turned everything off, bypassed the RCB on the boat (something i was hesitant to do) and the problem still occured. This led me to believe then that there was a fault somewhere on one of the ringmains. What I did next is to plug it all back in so that it was running through the RCB again and see wether i could work out what was causing the trip via the two circuit breakers. One seems to be for the plug sockets, and one seems to be for the overhead 240v lights. with the circuit breaker for the lights turned off, i havent had any problems with annoying trips so that has led me to believe that the problem is with the light circuit.
I've figured that the next step is to check all the light fittings and make sure there are no loose wires, i've had a quick look and can't see any loose wires anywhere, its probbaly worth mentioning that the trips have occured when there are no lights switched on. So now i have started to disconnect each light fitting, making sure each one is insulated with electrical tape to avoid any nasty suprises and that they cant touch anything metal or each other. I havent done them all yet and the problem is still occuring, but i assume once all the lights are "disconnected" then that would just leave wiring with no circuit and if the problem still persisits, then somehow a fault has devloped in the wiring behind the actual boat panelling (though i cant see how this can happen) i think if i get to this stage I will have to call in an electrician in as its beyond my level of knowledge but could there be any other possible causes?
One thing i should mention is that i have a flouresecent light in the bathroom and i have heard they can be a bit twitchy sometimes tho i have removed both the tube and the choke and the trip still happened. as I said, with the lighting circuit switched off then i havent had any problems with shoreline trips and the boat RCB still works when "test" is pressed. any suggestions would be much appreciated, thanx.
