Rincewind
Gender
Location
England
Occupation
Retired
Boat Name
Luggage
Boat Location
Shropshire Union
Rincewind's Achievements
Contributor (4/12)
45
Rincewind started following Curious Case of Bilge Pumps that can't reach the top! , Camshaft RPM sender - how does it work? , Different sort of boat and 7 others
Rincewind replied to cheesegas's topic in Boat Building & Maintenance
Depending on what you are attempting to do here I may have a solution. Question... are you wishing to repair / restore the revcounter back to its former glory? i.e. as per original spec? Or... do you simply want a revcounter that works electronically and is constantly accurate, i.e. not connected to the alternator in any shape or form as Quattrodave has suggested? If its the former then without physically examining the equipment you have, I may not be of much help, but if its the latter and you want a project to pursue, then I can point you in the right direction as some years ago I made, using a variable reluctance sensor (VRS), my own digital revcounter that is accurate to approx. 1 or 2 RPM at high engine speeds. (This accuracy was sufficient for my purposes, although you could make it even more accurate if you have the will to do so). As you already know, the variable reluctance sensor that you seem to have will output a sine wave signal (if it is working). Assuming that the signal is to be read by a microprocessor, that will most likely be housed inside the tacho instrument, the sine wave will have to be converted to a square wave prior to being fed into the microprocessor. When counting pulses, microprocessor's do not like sine wave signals and work best with crisp low to high square wave voltage signals. The point to note here is that, from the reluctor sensor to the tacho instrument, the cable you use should be of the shielded type with the braid grounded in order to prevent electromagnetic interference from other electrical equipment, e.g. alternators, corrupting the signal. - This can be important! (Less so important with Hall effect sensors as they are less susceptible to electromagnetic interference ). Hall effect speed sensors are also fitted with permanent magnets so "testing" the sensor by seeing if it is attracted to ferrous metals is not conclusive evidence of which type of sensor you are dealing with, however the number of electrical connections is a pretty good indicator. If it helps, I just measured the resistance of a spare reluctance sensor I have at home and it measures 777 ohms but do not read much into this as the resistance can vary widely from manufacturer to manufacturer. Also, be aware that the output voltage of a VRS can vary from as little as 8 volts to over a hundred volts depending on speed / make of sensor. e.g. The reluctor on my engine (over the flywheel teeth) at 642 RPM and producing1038 Hz, gave an output voltage of 152 volts - (both figures recorded on an oscilloscope). And that was at tick-over speed! Hall effect sensors normally output a voltage close to the supply voltage. i.e. If the input voltage = 5 volts then output voltage = 4.5 volts or thereabouts. -
I love it! Its even got Solar Power! Brilliant, The owner / builder of that boat and I must share the same sense of fun. It gives a whole new meaning to the phrase "about to descend the lock"!!!
Not a heavy cast iron one but we like it, comes in different sizes and colours. If you are tempted, buy the silicone grips that are made for and fit over the handles so that you don't burn your fingers. https://www.marksandspencer.com/cast-aluminium-4-5l-casserole-dish/p/hbp60268399?color=CHARCOAL#intid=pid_pg1pip48g4r1c2|prodflag_submsg-Induction compatible
From the Apple app store I have Neverspoons - self descriptive , and Caskfinder Unlike Pearley I found it very good, listed all my local watering holes with a full list of beers
Mine does, keeps the washer supplied without reduction in output pressure but empties the tank faster than normal!
I too looked at this scenario many years ago and questioned why Vee / wedge belts are used in this application. Having worked for a living on many diesel generation plants of different configurations, I could not arrive at a sensible conclusion other than it was nothing more than a historic and cheap solution to drive the alternator on an ICE. I.e., wedge belt arrangements can tolerate a little misalignment in several planes without being unduly compromised. (Automotive industry driven I suspect, with one eye on production costs and the other on third party repairs / replacements beyond their control). Beat me to it! the link below may prove informative. It seems to allude to that application. As regards your particular engine / alternator setup / problem, you may find this link interesting for Prestolite / Leece-Neville alternators:- https://www.idleproextreme.com/wp-content/uploads/2019/03/IdlePro-2pg-Flyer-031819.pdf I also have some technical information that I downloaded from Leece-Neville many years ago in PDF format that I could forward to you if you wish, via email. It contains info on pulley selection guides, output curves and recommended drive to alternator ratios etc. Sadly I can no longer find the link on-line but the PDF Data is still valid. If its of interest to anyone else........... Disillusioned with the traditional set up of the Vee belt alternator drive, with its many problems, twenty years ago I changed my Vee belt drive to a toothed belt drive system (water pump included). I used HTD pulleys and belts (20mm wide x 8mm pitch) using taperlock fittings on the crankshaft and water pump, matching the sizes of pulley diam. as close as possible whilst maintaining the crankshaft to alternator drive ratio. Due to its small diameter the alternator pulley was bored out to the size of the shaft and counter bored to accommodate the retaining nut. I retained the tensioning arrangement as that part of the setup is simple yet effective but it did require appropriate spacers in order to establish alignment of the pulleys. https://bearingtech.co.uk/collections/8m-timing-belts/products/960-8m-50-htd-8m-timing-belt-960mm-long-x-50mm-wide?variant=14242447261741 As far as reliability is concerned I can testify that after twenty years’ service, I have had no problems with the drive train whatsoever. As a matter of fact I bought two "spare" HTD belts at the same time all those years ago, - "just in case" - and they are still in the same protective plastic bag in the engine room, untouched and unused to this day. I checked the belt a few weeks ago, and it shows no visible cracks or deterioration! (But having said that, Sods law dictates that it will 'give up the ghost' and snap next time I am out cruising!) Benefits include:- No belt slip - hence better generation of power - and positive / reliable water circulation! Reduced belt tension - resulting in less stretching / wear of belt. (some tension is required to eliminate "belt slap") Less wear on alternator, water pump and crankshaft bearings. (No excessive side loading) Positive knowledge of drive condition if electrical generation problems should occur.
I have used a Karcher with the Patio cleaning attachment on the roof of my boat with great results, cleans all the green muck out of the non slip sand surface with no elbow grease required.
Have you considered that maybe the carbon brushes and/or the slips ring are worn, (or both!) causing intermittent excitement (or non excitement) of the rotor coils?
These could be Fresh Water Shrimps (cant remember the technical name) but you would have to identify them to be certain. They used to be quite common in the water supply pipes if the disinfection regime was ineffective - or at least the larvae of the shrimp used to be commonly found. When water flows from the service reservoir into the service pipes it is injected with chlorine to kill any bugs on its journey to your taps. When chlorine mixes with water it turns into an acidic mixture that dissolves the bugs. (which is why Mustard gas containing a high proportion of chlorine, when mixed with body moisture, blinded and destroyed the lungs of soldiers in the first world war) - Water companies are increasingly moving away from injecting chlorine gas and injecting Sodium Hypochlorite instead which has the same effect but is less of a hazardous substance to handle and store. The further the distance is from the injection point, the less effective it becomes and often - but not always - booster stations are provided to inject more gas / hypo if sampling indicates it is necessary. If the tap you are using is at the end of the pipeline the solution may be depleted and the bugs will flourish Fresh water shrimps are not considered harmful and swallowing them or their larvae should not do you any harm but should not be in the water supply as this indicates that other more harmful bacteria could flourish. I suggest you get the water from the tap tested by the relevant water company.
Arco Zeus regulator - first impressions and a look inside
Rincewind replied to cheesegas's topic in Boat Equipment
Nice teardown, thanks for that. Proof of the pudding though is in the eating! Hope you can update us -
Sods law strikes again......You always meet someone coming tother way in a Bridge ole!
I have used this material in the past. Not cheap, but rigid and looks smart. Nor am I advocating this supplier, just indicating what is available out there..... You should be able to get smaller sizes / amounts if you shop around. https://plasticsheetsshop.co.uk/aluminium-composite-panels/3mm/
Or look at it another way, ....... With an aging population and less children to replace them, ------- Housing problem solved!
