Most Cills in my cruising area are also marked, but as pointed out above by haggis once the steerer is below the level of the lock top he no longer has that visual indication. If the boat is a bit on the longish side, around the time the steerer should be concerned about the cill his crew manning the lock gate are likely to be shouting that he needs to move astern a bit so they can get the gate open. When he sees the cill of course it is far too late. The steerer should remember, he is in control, advice from the lock top is welcome, but the cill is more important. The other can be sorted out later.
Someone earlier in the forum mentioned port/starboard lists in locks due to mooring ropes which reminded me of an incident some years ago when locking down on the Thames. I recon the lock keeper had crammed about 14 boats into the lock. Steel hull boats along the edges, plastic boats in the middle. As the lock emptied I noted that we were starting to list a little. At first I thought is was just my crew moving from one side of the boat to the other. The listing rapidly worsened, I then discovered that my "rubbing strake" was hung up on a protruding brick in the lock side. Shouting and screaming at the lock keeper did not seem to be working. When the plastic boat next to me started to make strange 'creaking' noises I pressed the horn and kept it pressed. That did the trick. However, by the time he got the sluices shut we were over at an angle of 30 degrees or more, and small cracks were appearing on the gunwhales of the plastic boat where the fenders were starting to make indents.
It does not happen often, but hanging up on the side of a lock is something else to be aware of. Also, to avoid sinking, make sure that horn works!
Radiomariner
