Your assumption is very correct , the head gasket is gone right ? Thanks for your guidance. Highly appreciate...Video and Photos Included...Any advice to my friend ??
https://www.youtube.com/watch?v=sqhdMA2zy98
Head
Head Gasket Side 1
Head Gasket Side 2
No he didn't put the head into a degreasing tank,I told him to remove the head and inspect the gasket as you instructed me,he will do it tomorrow.will update the thread tomorrow,Thanks for your valuable suggestions
Thanks for the reply
Thanks for the reply I had a problem in my Injector Pump as well,but I repaired it,dont know wheather the problem still exists
Thanks for the reply OHH thats Cool,good that you told it
My friend said me that he replaced the head gasket with a new one, however few hours back I noticed that the diesel is floating inside the expansion tank,(video attached),it could be a problem in the head gasket right ? Thanks
Thank you very much for the reply, Its a 1.5 BMC fitted Morris car not a boat, one of my friends did the overhaul, he is a amateur.my friend said me he faced the engine block, but not the head.Not tested for cracks What should I do now
Hello friends My Newly rebuild 1.5 BMC engine overheat and stops after a few minutes.what could be the problem? Videos Included Thank you !
https://www.youtube.com/watch?v=tiGesnKDvKI
https://www.youtube.com/watch?v=9WRMFuXW2KM
https://www.youtube.com/watch?v=URQag5yo6IE
Hi ,I recently rebuilt my BMC 1.5 engine and, around the same time, removed and rebuilt the CAV oil pump, but now the oil won't come out of the pump... however, when the metering valve is removed, the oil comes out fine... what may be the problem? Thank you !
Metering Valve is Squred in Red
