About mtbvincent
- Birthday 27/03/1985
Gender
Location
Puttershoek
Boat Name
Luxor ( Connoisseur 900)
Boat Location
Holland (Puttershoek)
mtbvincent's Achievements
Explorer (2/12)
13
By coincidence a diesel specialist stops by at my work just now. So I asked him to take a look at the picture of the shaft and his thoughts. He said this was a 100% the problem. The twisted shaft / tooth combination resulted, for example, 3 degrees on the shaft is 1.5 cm or more on the pump housing. I am still seriously happy with the rebuild specialist, sh#%@ happens, and I am just glad it runs so well right now ๐.
It's a beautiful day guys! The engine finally runs like a new one! The fuel pump has been refurbished again.... and the main shaft has been replaced. Apparently this was the problem, not a 100 sure but ok it works finally! So happy i can enjoy my boat again ๐ฅฐ. I want to thank you guys for all the advice and helpful ideas. It's been much appreciated and i am thankful for your time. Here is a video of the engine running With kind regards, Vincent
The engine til runs like *^% contact with the person ho has rebuilt the pump, and he wanted it back for a check. He took everything apart and the main shaft inside the pump has a crooked tooth. It is a thick tooth sow we think this may have gone wrong on the test bench. So another one went in, and the pump is ready to be fitted again. The idea is to get the rebuild specialist to mount and adjust and set the pump on my boat.. Only he is a busy man lives 2 hours away, but hopefully he can make time on a short notice.
Thanks, I will set the pump on the mark and give it a good run. Curious for the outcome๐
A friend told me to go out and spend an hour or more on the water so the engine en exhaust can dispose of the build up dirt from all my cold starts' en messing around in the harbor. Even try a bit of cleaning fluid in the raw water intake when the engine is hot. As you know, my fuel pump setting is kind of a mystery for me. Turn it left, right, or just leave it on the mark? Can someone help me out, is there a basic setting I need to find after replacing the pump.
Thanks for the time @Tony Brooks When i have some news i will keep you updated ๐ค
Thanks for the help guys, something to think about. My impeller pump has been replaced last year, so this must be in good condition, the water pump of the engine is a couple of years ago. Is there a way to check for malfunctions in the cooling system ? Where should I start to work in a logical order?
Morning guys I did place the injectors and the engine runs smooth en sounds better. Still got the white smoke ๐ค The only thing i can do myself at this moment is adjust the fuel pump. Can you give me an idea about the timing and how much i can change the position of the pump? For example, can i rotate it by 2/3 mm or should i even try 1 cm?
The injectors are back and I am glad I brought them to the same person who did my fuel pump. He delivers professional and perfect work. He did a test and the injectors were bad. Sow he refurbished en adjusted them with new parts. Hopefully I can fit them next week because I am curious if my money and time eating Bmc has a full belly ๐
Thanks this is a clear message. I wil have them done by a proffersional ๐ When its ready and fitted back into the engine i will inform you guys. Thanks for the feedback ๐
Thanks guys! sounds like a plan, i will take out the injectors. To make shure its works well i will take them all out and clean them like the example of youtube. When this is done i will lett you know ๐
Thanks for te repley , I did ajust the pump a bit something like 2 maybe 3 mm left and right. Did not realy make a diffrence. How far should i go i did not go as far a 4mm ore more... This is the current setting on the picture.
Greetings everyone ๐ back at it again. Last year I replaced the injection pump because it was leaking inward to the oil pan. After this repair the engine doesnโt run a nice as I wish, It smokes more than usual.. The timing of the fuel pump is correct. Is it possible that the fuel pressure is stronger and my injectors are leaking/dripping? Can you guys advise me to replace something or is there something i am missing?? Hope someone knows a way to help me out.
The next step i will take will be next year. I've gathered some more information and the next thing to check is going to be the timing. There is a small.. Small possibility that the axle of the injector pump (inside the engine) has come out of place when i took off the pump. I don't think its possible however it needs to be checked! For now... I would like to wish you all a Merry Christmas and a Happy New Year.
Thanks a million for your patience and the efford you and other members take to help me out ๐ Ok the part of the injectors sounds logical, and before everything worked fine.. so no need to just replacing it now. I have a picture of the parts that have been replaced it seems to me its very complete and correct.
