Red 25mm2 cable comes from back of boat into a 100A fuse then onto pos terminal on BT battery, a red 60mm2 cable then comes of this terminal to a 350A fuse then on to an isolation switch then onto the BT.
Black 25mm2 cable comes from back of boat straight to neg terminal on BT battery, a black 60mm" cable then goes from this terminal to the BT.
The pos feed to the control unit comes off the BT battery terminal and I have to remove it to take the 25mm2 red cable off, so no the two arn't connected when I measure the voltage in the engine bay.
