No worries. I wouldn't hold anyone to advice given freely on the internet, unless the same thing was said by many sources ( good chance it's the right answer then), just looking for anyone input, even if it's not the right answer, it might spark an idea in me or someone else. Either way I'm always grateful for any knowledge.
The outboard came with the boat, wouldn't have been my choice. But I'm reluctant to spend on a replacement when the future is an electric drive when finances allow.
I think I've solved it!!!
Just looking again at the photo, I've realised that the metal clip that the pointer slides over is 90 deg the wrong way so it catches when you change from fwd to rev. Might not be that simple but I'll try it.
I understand, I'll have a look through the parts catalogues. I suspect the part numbers may be the same. I do't know a great deal about these engines, but why would you suspect an ignition module if the engine cuts out when hot ?. Is that the most likely cause ?. Thanks
That sounds like a plan.The engine starts and runs fine and cuts out intermittently after about an hour of use. Cuts out quite often when manovering fwd and rev, so that burnt out little lockout switch maybe the cause.
I didn't realise ignition modules were interchangeable, that maybe the next issue. Thanks.
That makes sense. Thanks. I think it's knackered and disconnected. The engine will start in gear.
I've taken the carbs off for a good clean, engine keeps cutting out randomly for no obvious reason so just trying to get to the bottom of it. Appreciate the help.
Thanks for the information. I have the drive unit attached to the prop, all the hoses are in good condition, there's a hydraulic tank, prv but no pump or engine. Was curious to see if it was possible to try a different way, but maybe it's beyond practical, without spending lots. But thanks.
Hi, yes it's the same boat. The outboard is fine (surprisingly) steers better than most in reverse. The outboard is only a short term solution because that's how the boat came. Long term, when finances allow, I want an electric drive.
The reason for all the questions is I'm just looking to utilise what I have already before I spend money. (I am Scottish after all)
Thanks for the reply, it is designed to be enclosed as it has it's own enclosure with forced air intake and exhaust. It does have an auto shut down in the event of CO2 build up or air intake failure. Exhaust is submerged. And it is remote control for start up and shut down.
I wouldn't take the chance with anything else.
It's a 10KVA genny and it would be going into the engine space under the rear deck (where the original engine and pump would have been). The reason for asking is these are the things I have and I'm trying to see if there is a way I can use them.
