Hello Sir N, may I pick your brains again please? Am I right in thinking that with the starter assembled but solenoid de-energised, rotating the pinion shaft up the helix by hand it does not enable it to go far enough to reach the locking position ?
Does it need the solenoid terminal to be powered up and solenoid engaged in its forward position, and with the four segments magnetically retracted into the solenoid, before it can then be moved out manually enough to allow it to reach the locking position ?
I have re-assembled as far as I can see correctly, with all parts accounted for and seemingly correct and undamaged, and the locking mechanism works on the rotor shaft by hand. The engine its going on is 50 miles away so I would like to confirm as much as possible on the bench before trekking of to install it.
If my memory serves me correctly we used to test these by running them in a vice with a length of 3x2 timber wedged under the pinion as a load !! produced some nice semi circular patterns in the timber !
Horror of horrors - but in my defence, it was before the days of the H&S at work Act !
