Morning all,
I'm new to canal boats and am fettling a 62x12 widebeam. I fired the heater up (Webasto 4.5kw) for the first time and it ran beautifully and warmed the 6 radiators up a treat, really warm.
The water was cold, so after a bit of pipe tracing I located the gate valve to the calorifier and opened it. I could feel the hot water from the Webasto going into the tank so waited patiently.
After about half an hour the radiators were much cooler, in fact just warm. I expected that the calorifier might rob a bit of heat from the rads but not that much. After another hour I had warm water and warm radiators, nothing hot enough to be of any use.
Engine heats the water fine, although the coil in the calorifier is separate to the Webasto so probably not relevant.
Is a 4.5kw heater enough for so many rads, calorifier and a big boat? When I shut the calorifier off the rads warmed up again to a proper temperature. I suspect the unit's not big enough to run everything? ambient temp was about 6 degrees on the day I tested it.
Any ideas or anything I've missed? Thanks in advance,
Pete
