I need to replace the engine cover on my Semi trad NB. I currently have Hexagrip deck boards which is what I think I should use again (unless any other suggestions)
Can anyone suggest where I can purchase Hexagrip deck boards from (near/in Northamptonshire)?
Thanks
Terry
Thanks everyone for the advice.
I now know the back and sides are steel. holes are at the top of the unit and due to rust. It is at least 15 years old.
I have decided to replace it. Been thinking of putting wood burner in the garage, now I can. Boater in the marina has agreed to do the work. Now I have to find the replacement. Any suggestions welcome. NB 47 foot and used for holidays only.
Terry
Had the safety check completed on my NB yesterday. The Woodburner stove failed as the back plate has a couple of holes in it.
Can I get it repaired? if so, it is worth the cost?
If I decide to replace the stove any advice/help on what I should buy?. Any suggestions on who I could get to fit the stove. NB is in Northamptonshire.
Thanks
Terry
thanks for the replies. If PRM recognise the difficulty why have they not provided a better dipstick solution? I have never had the problem reading a engine dipstick.
I tried removing and cleaning the dipstick then putting the dipstick back into the geabox but not screwing it down then remove and check. I spoke to the engineer who fitted the gearbox and he told me using this method, the oil must not go above the bottom marker. seems to work.
Hi everyone, changed the oil on my PRM 150 gearbox but when I check the oil level I find it very difficult to tell if there is oil on the dip stick. Is it just me?
Terry
Wow - very impressed. you should all become salesperson. You did a much better job than the guy I spoke to in the O2 shop. He said don't bother.
Thanks
Sorry if this has been answered several time before.
I am planning to spend a couple weeks on my NB. I intend to take my laptop so i can surf the internet. However, what is the best method? I an told the broadband speed is very poor, is this the case?
My new PRM 150 gearbox. needs it's first oil change. However, I cannot get to the sump plug. The engineer said he removes the oil by pumping it out rather than drain it. Is that what others do? and if so, what do I use? and where do I get the required equipment from?
I am having a new engine fitted this week and was planning to have a cenntaflex coupling fitted to relace the existing bronze coupling. Is it worth it or am I wasting my money?.
Thanks
Thank you all for replying so positively. I feel much better about my decision. I am particularly please to hear the engine should not be to noisy.
All I have to worry about now is getting the engine fitted. It as appears my NB keel tank is too small and the engine beds are the wrong size and nears cutting out and new ones fitting.
Thanks
Am I doing the right thing by purchasing a new Isuze 35 for £3,000. e.g. are they reliable? are they noisy etc?
I think they may not be the best on the market but good value.
Thanks
Sorry to be a pain, but yes we have instant hot water heater and it's great. However, would also like a calorifier. I am also thinking of fitting out the bathroom. Currently, we have 4 inch deep shower trap which we empty, using pump, once we have finished showering. Are the B & Q shower trays deep enough?
OK, I coming round to keeping my engine (anyway, I don't like spending money). However, I would like to fit a calorifier to provide hot water via the new engine. Can I run this from my existing engine? if so, what do I need for the engine attachments? if not, what are my alteratives available?
