Misterons
Posts posted by Misterons
You've probably sorted it by now, if not, I just had the same problem, Nicknorman nailed it with moving the pin to the furthest out hole, perfect! I've put up with this for years!!
thanks all, i think that's covered it, much appreciated.
Ron
My 22 year old PRM 80 has developed an oil leak from the output seal (slight spraying around bilge) does anyone know the the flange nut size before I strip it down and find out I don't have the correct socket! Also, it has had CC grade engine oil in from new, only changed once! should it use ATF ? Manual says engine oil but get conflicting answers on other forums. Cheers in advance.
This stuff is oiled based and according to their tech. it mixes with Owatrol. Tried narrowboat paint a couple of years ago, and to be honest, it went dull and was a bit pricey, so you don't always get what you paid for. Brushed on. by the way.
Anyone used Crown exterior gloss to paint their narrowboat?
PRM 120 output seal
After taking out a mortgage for a genuine output seal for my PRM 120, just bought a spare for £4.55 inc VAT and delivery from a seal/bearing supplier. Seal is 40mm x 52mm x 7mm. FYI.
