canalboat77
4 Neutral
  • Occupation
    Boatman
  • Boat Location
    Yorkshire
  1. I've just purchased one of these horns and when they go off you can probably hear them from London (we are located in Yorkshire). Does anyone know of a way to slightly lower the noise level? Other than an old sock! Thanks https://www.midlandchandlers.co.uk/products/aaa-12-volt-stainless-steel-marine-twin-trumpet-horns-ad-113
  2. So I took some readings.....I have two alternators, one for the starter and one for the domestic batteries. Alternator 1: 14V Alternator 2: 14.6V Battery Voltages when engine running = 13.2V and 14.7V Battery voltages when engine not running = 12.9V and 13.5V Really appreciate everyones help/response.
  3. What reasons would my control panel start beeping? I assumed it would be because the batteries are low, but as you can see, they are fully charged? https://share.icloud.com/photos/0ach0cr9vxaAV6GLj-UdqVtEw Thanks in advance.
  4. Just remembered I didn’t provide closure for this topic, and figured maybe one day someone else might have this issue. The culprit was……temperature sensor out of the box was faulty. I guess I just assumed as it was new it worked. 😒 That will teach me. Switched it out for a magical Bluetooth dongle and it’s all good. Thanks everyone above for all your help. Much appreciated.
  5. You are correct - this is the setup I had. Apologies to everyone for asking the wrong question. To be fair the person I asked said it "might" be live on negative. As it's being discussed - what is the best wiring setup for a bilge pump? We would like to be able to manual switch it on from the control panel as well. Thank for everyones suggestions and time.
  6. I have a bilge pump which needed replacing and was. When I took it apart I didn’t pay attention to the wiring (I know). I’ve been told the switch on the control panel is live on negative. Can anyone explain what that means, or better still have a wiring diagram? Lesson learned for next time! Thanks
  7. I know in an ideal world before repainting a boat you would remove all the previous paint down to steel (on about the top section - nothing under water.) If you don’t have time to do that what grade sanding disk would you take the boat down to. Last year (different boat), I think we went down to 180 grade before we painted - does that sound right? Thanks
  8. Thanks so much for your reply - makes sense, I’ll just keep doing the same.
  9. Every two years I paint the bottom and sides of my wide-beam narrow boat . Last time I painted the bits which get wet using Rylard Rytex Bodied Bituminous Coating. Recently I keep seeing on youtube boaters making videos about using 2 pack poly paint. Should I be using this first, and then top up with the Rytex? Just trying to get the hull and bum to last as long as possible. On the Leeds & Liverpool canal which isn't very deep. Thanks in advance. PS: I'm actually required to paint this often (MCA friends insist - LOL).
  10. Yeah, I’ve done the first step and opened up a support ticket with Midland Chandlers - where I purchased it from.
  11. Ive only just had this connected and as soon as we did, we had the two lights.
  12. We used to have a Heart Interface Freedom 25 Inverter, which I believe had a rating of 2100 watts, so less. Are you recommending we fully charge the batteries (I have a couple of chargers), and then reconnect them? Thanks.
  13. Here’s a zoom of the cables. The person helping me, who didn’t install this says they look big enough. Do they? Yes I think next step is to try some new batteries to just rule this out. Just got to find someone who supplies them.
