Hello Tony, I fitted the Jabsco tank ..but tried the first suggestion I had first (switched on pump with taps closed...until pump stopped.. then let air out from schrader valve until the pump cut in again)..
Performed exactly as it had before... with taps all closed, pump on for about 5 seconds then off for 1 to 2 minutes then on for 5 seconds etc.
I guess the original accumulator was not the fault but at least I have a much lighter, newer, easily rechargeable tank now!)
There are no water leaks so I assume the fault must lie in the old jabsco PAR pump discharge valve (or pressure switch?)
Thanks
Neil
