Gender
MarkCC's Achievements
Engager (3/12)
3
That other thread was about my other boat. Different alternator different boat. The alternator on the bmc is the a127 lucas (copy). That's pretty common. No idea how it broke, boat is over 40 years old - these things happen. Maybe some damage hairline fracture some vibes! As well as the 2 top supports there's the 3rd lower post - which has the 4th adjustable part via a bracket. The below image is before it broke - its the piece below the water temp with the red wire). The top (as you look at it) bolt goes through a bolted on 90degree bracket - which is the engine diagram in my manual part 64 "bracket for alternator". Theres a load of washers needed to help things line up. This alternator is a fair bit bigger than the original - though has been place 4 years plus.
Thank you for the confirmation. Not sure how or why I have put it down to old age - it was a fairly clean break. Mark
Thank you so much. Probably saved me hours of looking. Instead I shall spend hours thinking about wether it's a DIY job or not. Then attempting it- it going wrong - and then spending weeks finding someone with the right skills. All good stuff! Thanks again.
MarkCC started following Alternator identification help and Part identity help
Hi BMC 1.5 (note this isnt my engine image in this message but rather a general one as I couldn't get a decent one of mine in situ) The part circled I need help with. It provides part of the support for the alternator. Its unfortunately broken off, having looked carefully today it looks like it's part of a piece- rather than the engine block itself - probably do do with the coolant loop but also has the pulley for the alternator belt. Checked my manual and can't see it on there. if anyone knows what it's called and if it's a sourcable replacable part I'd be glad to hear the details. thank you Mark
MarkCC changed their profile photo
thank you both. Mark
hi I'm replacing the alternator on my current project - but having removed it the part number on it doesn't seem to bring up anything. EI20C4 Its a Mitsubitshi 3E engine. If anyone has any ideas or can suggest a replacement I'd be grateful. Ideally the same-ish unit size as space is tight. many thanks Mark
1980 springer I suspect the engine is newer Its all a great learning ...
Its a 32ft springer I feel a bow thruster is somewhat overkill. The boat has many a mystery pipes been slowly working through them. But a pair of the hydraulic pipes go up into the " control " pedastal/box - which has a hissing gear lever - back neutral forward. There is also a 2nd lever that controls the revs (though as mentioned it only revs when in neutral) The only way we have been controlling the speed is by taking it out of gear, gliding a while. Its doesn't go crazy fast no faster than any other boat. Have a rev counter and it stays around 900rpm whilst in gear.
I'd love to have a ferkle, and even a gander. I suspect as mentioned above its been erroroneously plated over. Oh the joys 😂 Ferkle is a good name for a boat. With this boat I'm on unfamiliar canal being on the Grand Union near King's Langley (heading - slowly south, well at top speed in small bursts) if there is a decent beaching location or similar in the general area be good to have a look whats going on. Thank you
Thanks Yeah anti ventilation plate out of the way there is another metal plate in the way stopping me getting my arm down to the propeller. It doesn't seem to want to move etc
A couple of hours cruising and she topped out at 85c- so I think the main issue with the water pump etc is sorted atleast for now. Following on I think the prop is having issues as the boat struggles under load (loads of smoke - enough to cause second looks etc - adding the fact she only goes 1 speed im sure to be terrorising other boats) So, have a look at the prop because that might explain a few issues. Firstly it does turn by hand but is very stubborn. Into the weed hatch.. its the bolted down variety but get in and I am able to remove the foot type piece. Haha I think now to look at the propeller ...nope there's another piece of metal blocking me getting to propeller... It does have a bit of a gap as I poured some water in and it drained away. Answers on a postcard Thanks again for your knowledge and wisdom.
Thanks Tony I knew I would be caught out with needing more info. Not an upto date picture as I have put in a bilge pump since this picture was taken .. 😉 The metal square box. With the qx 32 (?) oil I found on board. The gears make a hissing hydraulic noise when engaged so assumed the gears but there are various pipes going hither and tither so maybe the drive too. But this boat seems a wonder of mysteries and oddities.
I took a picture of how it was arranged before and put it in the same way. I stopped worrying about the belt tension following some advice above. I've cleared the pipes and I think there might have been a blockage caused by the knackered impeller. Been running for 15mins now happily sitting at about 70degrees. So my current thinking is broken impeller plus debris from it stuffed it up. Thanks everyone for the help, assistance and reassurance. We take her for a cruise tomorrow and see how that issue goes. And just whilst I have the thread going anyone have any ideas why the boat will only go one speed? It will rev up whilst in neutral, but as soon as I put it in to either gear it does not rev at all. Its a hydraulic gear system (another new thing for me) I've topped up the hydraulic oil etc
The raw water comes in goes around and up to the metal cylinder box thingy (not sure what its called) comes out then down into the bottom of the pump then up and through the housing where it joins the air exhaust - down to a 'mud box' then out ... If that makes sense (sorry still learning the jingo for wet exhausts)
