Petalsnow
Everything posted by Petalsnow
Worked a dream. Thanks again!
- 43 replies
- electricity
- 12v
(and 1 more)
Tagged with:
Thank you Alan yes I will pm you. This would be helpful!
- 43 replies
- electricity
- 12v
(and 1 more)
Tagged with:
by the standard, diy. We are refitting her. That’s really useful thank you. We will make sure these are used. Really glad I checked.
- 43 replies
- 1
- electricity
- 12v
(and 1 more)
Tagged with:
Hi, We have just taken a plug socket off the wall (electricity off) and found it in this interesting state. Does anyone know what causes this? Could this be a future problem? To us it looks like a fire hazard so it will be coming out. No idea how old this socket is as it would have been installed before our time - potentially over six years. Thanks! Gemma pics attached
- 43 replies
- electricity
- 12v
(and 1 more)
Tagged with:
I'm not sure on the ply. It is sturdy but the fabric was glued down so would definitely need some work! You advice is really helpful. Thanks so much! This sounds so lovely. I really appreciate knowing how you would recommend painting if you did it again. This will help massively! I think we will be going white too as we are also liveaboard. Totally agree on the wipeable aspect!
I think you're right! We did think it was something like what they have on yachts. Thank you so much! Brilliant! It's really useful to know that you managed to paint though. Thats really helpful thank you.
We are in the middle of renovating our narrowboat (aren't we all..) and have come to the point where we need to rip off the material that is above the gunnels. Firstly, I'm not sure what the material that is on there currently is called. It is glued on and thicker than wallpaper, easy to clean (wipeable) but peeling at the sides and a grotty colour. Other than it being grotty/peeling in multiple places it is inoffensive but haven't been able to find anything like it anywhere. Any ideas what it would be called? Picture attached of this. We have put wood in under the gunnels and are wondering what others have done above the gunnels to complement? It potentially would be difficult for us to paint due to the glue that is already on the underside of the wood. I've heard about vinyl, wallpapering, carpeting. We do have leaky windows/condensation so questionable what is suitable. Thoughts welcome!
When to remove masking tape when painting panels?
Petalsnow replied to Petalsnow's topic in Build Blogs
We are actually in a dock so under cover, would that make a difference to your answer? We have a number of coats to do on the actual panel so don't have the time to wait for the outer paint to harden more than a day. That's why I thought that we would be four days until we could definitely take the tape off (if we left it on). We would have one day of drying on the outer and then a layer a day for the gloss panels. Or is it all because of the tape that has been stuck to the paint for a while is a risk? Thanks Gemma- 18 replies
Hi, We have painted the outside of the panels on our sides and are yet to paint the actual panels. We have heard that we need to remove the tape whilst the paint is still wet - but won't have painted the inside of the panels until later this week. When do you recommend taking the masking tape off? Do we remove the masking tape straight after painting the final coat of the outside of the panels, then re-mask when we come to paint the inside of the panels? Do we just leave the masking tape on, even though it'll be another 4 days until we finish painting the inside of these panels? We are painting over night because of work so time is a little scarce. This is where we are up to: https://www.instagram.com/theadventuresofdreamcatcher/ Thanks so much for your guidance! Gemma
- 18 replies
Oh crikey! Didn’t realise it was so old - should have checked ? thanks! I’ll get my string out then.
How long did it take you to sand your primer/undercoat. We are almost at the sand it back stage after painting these on a 70ft and trying to understand how long it’ll take us!
What size roller would you use? We are using 4", but surprised with how long it takes - maybe we are just slow in comparison to others we have read about.
THat's fantastic! Thank you so much!
I understand now. OK, thanks so much!
We have a walk way on either side right now!
That makes a lot of sense. We were thinking socks might be the way forward. So you wouldn't suggest socks on the side of the boat leaning over?
The previous paint job was appalling! Though I'm still dubious if we can do better... SO we used a scrambler and angle grinders! Did the trick! Thanks everyone
Hello, We foolishly decided to paint our narrowboat roof and sides. Once you've completed the first primer coat and you have paint over the roof/sides/foot rail. How do you get to the roof without dirtying the paint? I'm not that short, but my arm still doesn't reach the centre of the roof for laying off/rollering. Tips welcome!
What would you recommend to take off the paint on the side walkways along the narrowboat? Eg. Where you walk along that has the sandy paint for grip. Fast stripping metal disks seem to work well on the angle grinder for in the corners. Taking back to metal.
My regular steel built in water tank has an over flow pipe which snapped when we were doing work. Can I just seal it up or will this cause an issue with pressure in the tank? How would I replace a snapped over flow pipe? This is the only way in getting air into the tank. Thanks!
Brilliant! Thank you so much for your help!
100% not going as far as Leicester for obvious reasons! Is the BW (water mate) key not the same as the 2 keys you get from CRT? Where would you get one of those? Thank you so much. Your guidance is incredibly helpful! ps. I’ve seen about Ivinghoe - Thanks for the tip off!
Our handcuff key is in the post but we are not likely to receive it in the next week. If we are travelling from Tring to Welford on the Grand Union (and Leicester branch) are we going to need this key? Or anything else we don’t know about yet? Thank you!
