If you look at the diagram I posted earlier in the post it looks as if spindle 58 has seized in bush 53. You may be lucky and free it off with soaking in WD40, bur I have my doubts. To be able to remove this spindle you would need to remove the timing end cover from the engine, and then remove items 19,20 & 54 from the underside of the spindle, then it should come out. Although if seized you will have a bit of a fight with it. Also when the end cover is removed you'll probably be working blind asI suspect you won't be too far from a bulkhead. I would respectfully suggest tat unless you are sure of what you are doing find an engineer to sort things out.
