Hello all out there, Thank you all for showing interest and putting your thoughts forward. Yes the travelpower does indeed run the cooker when we use it. The 360AH Leisure batteries have to date been more than adequate for all our needs and the batteries are currently in good health. Its not good to eat beyond 8pm. The 48V power pack is 4 x 12 200ah LiFePO4 with BMS for each bank. To add to this the Leisure batteries will be increased by another 360AH. These are to be charged by solar panels but will be able to be charged via the travelpower/standard Alternator if required, a BSM covering all the Leisure batteries will maintain a log and cell balancing. The BSM on the leisure side will switch in Batteries to suit the current loading conditions and drop out those not needed and into the charging bank queue.
The real issue I am facing is the Clutch. I plan to keep the Beta inside the sound box and intend to mount the LEM in its own frame. The LEM can (this is as I see it at the moment) have a centrifugal clutch on it. This can be belt linked to another centrifugal clutch on the prop shaft. This way the Beta can drive the prop and not be loaded by the LEM, and via-versa. As I have said the LEM does not need to operate as a GEN but it would be nice to have the option. I think this system will work but I do not know enough about the clutches and if there is another solution I should be aware of. The mechanical centrifugal clutches are not that expensive which is good and I like to keep the mechanical elements simple.
Phill
