Ah excellent i will keep this in mind gor the time when i will spill stuff when i am doing the service. Work has got in the way atm but i will be back on it soon. Thanks for the tip
Ah yes sorry i miss read i was exhausted its been non stop. No pun intended ?
i will strip it down and see what kind of condition its in. That says to me that i could possibly use brass or get some custom made rubber maybe.
Ah ok i might just clean it up if its in good condition
Freds me dad btw ??
https://1drv.ms/u/s!AsWfN-2PkNmMqiaIjbdJ_oW8ZA5z
https://1drv.ms/u/s!AsWfN-2PkNmMqictxF1sR2c7CFIr
A couple more pics from the boat. Its a bit scruffy but its a diamond in the rough. Had to leave the apprentice cleaning up today as i had to get a van to help with some of the heavier bits needed.
Ah ok i will strip the wrapping off it and have a look. I was in the future going tp custom make a stainless exhaust to give it a long life. Steel just dies too quick especially around water. So the rubber caps are there for flex and movement? Or are theyfor something else
https://1drv.ms/u/s!AsWfN-2PkNmMqX-QL1bA8ALDO_sr
Cleaned out the engine compartment it was a mess. Put some saw dust down to soak up the smelly liquid. Pumped out the coolant tank and going to have a look at it today
I'd love a perkins, maybe on the next one
Sorry for slow reply i Just had the weekend off and back on it today. Yea the engine bay was a mess bought out 3 bags of random junk wrappers and grime. We've got everything ready, tidied and cleaned, going to get on it first thing in the morning I'll try and take a few more pictures.
Thanks WotEver i am looking forward to it and then enjoying it.
Engine bay after a clean
Figured out how to do it, thanks for the help ?
Yes of course it will be stripped down first, i won't do the fit out for a while yet. I am going to strip check and fix if needed. Sorry i must have missed out the fact i am a welder by trade in my post.
Ah yes it is 84 the insurer dont need a survey its a bit more than some but i will see about it, because i would prefer to survey it later when it is fitted out, so going to do a bit more research first. The best way i see it is to find a better insurance company and do the hull survey to cover the engine and hull.
Ok yes this was what I was going to do after I got the engine sorted. I want to strip down the whole thing and check all the bushes and refresh them. It has a tiller arm and a steering wheel and dont mind that set up. Yes I will have to do something with the weed box to make it more accessible as atm it is bolted down and I would like to improve it. I was also thinking of stripping the stern tube down and repacking it just to be safe. Thanks for the advice I was going to get into that after the engine is sorted.
Ah yes, I thought 4mm was the smaller boats but not sure. Mine is 6mm and there is no spot less than 5mm thickness. It will be getting stripped back inspected thoroughly and fixed if needed.
Yes I have countered in the bsc. I was thinking of doing that the same time as the hull blacking. Not sure weather I will go with bitumen or epoxy yet.
I have sorted out the insurance and will be going fully comp and have a few companies I have contacted to get an idea of what is required.
Brilliant thank you for the link to the history I have been searching for bits and information on them.
I think I will try them on a program I have to shrink them to do it that way, as the pictures will be permanent. If the hosting site goes down they will be lost.
Thanks Alan very helpful comment
