Hi Folks,
Sorry because I know you get a lot of these request. I am looking to buy a boat in Scotland and this one is for sale....
https://www.gumtree.com/p/for-sale/57-ft-narrow-boat-spectre/1375399916?utm_source=WhatsApp&utm_medium=social&utm_campaign=socialbuttons&utm_content=app_android
Additional info:
The boat was blacked in August 2019 with Keelblack (6 coats on the side and 4 coats on the bottom).
Mitsubishi K-series engine, oil filter and oil changed in 2018.
Boat Safety Certificate valid until November 2022.
Fully refitted and insulated with 25mm Ballytherm, hardwood finishing on walls and ceiling.
Lots of storage space, large kitchen with full sized oven, a two burner hotplate and a microwave. Under counter larder fridge. Large chest freezer kept in the storage unit at Applecross.
Multifuel (coal and wood) stove, two movable oil radiators with WiFi timers.
Two 110Ah leisure batteries and a new starter battery bought in 2018 and a 30a battery charger for shorepower.
Petrol generator.
Thetford cassette toilet.
Dehumidifier.
Alarm system fitted with door and motion sensors.
Wall mounted 32 inch HD TV and a couch settee.
Built-in seating area and a pop up table under cratch cover.
My main concern is regarding the hull - attached is the survey from Spring 2017. There does seem to have been some corrosion (neglect?) at that time. The boat has since been blacked twice (at that time in 2017 and again in 2019 as detailed above) but only with bitumen not grit blasted an epoxy coated as suggested in the survey. Do you think this will be a problem? Is it worth having it grit blasted and epoxied now? Any other glaring concerns with the boat?
It is in an ideal mooring and boats are few and far between on the Scottish canal networks but I am worried there are big issues with the hull?
Thanks in advance for any advice.
Damien
