Hi Brain,
Thank you for your help! This is the best manual I can find for what I have the Cotek SK2000 (the slightly older model). https://www.manualslib.com/manual/756317/Cotek-Sk700-112.html?page=20#manual Says on page 20
3-2-4. Use wire # 8 AWG to connect Chassis ground with vehicle chassis
Over Voltage
Model
Shut-
dWARNING!
WARNING: Operating the inverter without a proper ground
Connection may cause an electrical hazard
I have a gravity fed back boiler o my boat.... problem with it tonight.... the water is suddenly dropping in the high up water container and then its bubbling and rising up and spilling over and flooding the cupbard where it sits... anyone any idea what is going on? Up and down up and down
If we can't repair the old flanges could we simply replace them with 2 of these Lister CS flanges below and insert the new flexi pipe in? It is not proving easy to drill the old felxi pipes out with a standard holesaw...
We have completed the important milestone for this project of getting the bolts and the flanges off.... the top bolt that had welded itself in was a challenge! lol. Do people think these are reusable flanges? looks like a job to get the old exhaust pipe ends out.. were they threaded in or brazed? Is it possible to get flanges like these easily? they look a lot thicker than the ones I have seen on a quick google search. Warmly Tom
Thanks again for all the advice.... it is helping us a lot.. do people feel I will need the flexible exhaust bellows like on the link that the chap sent above (https://www.midlandchandlers.co.uk/products/bellows-with-1-1-2-bsp-male-ports-20-length-ea-009) that has the 2inch or 1.5 inch ports? The diameter of the flexible pipe in the middle part seemed to be around 1.9 inches... we could see the boat has an old style manifold on like this (https://www.ebay.co.uk/i/133467674270?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=133467674270&targetid=939009504906&device=c&mktype=pla&googleloc=1006465&poi=&campaignid=10204071489&mkgroupid=107296306292&rlsatarget=aud-629407026465:pla-939009504906&abcId=1145987&merchantid=113627617&gclid=Cj0KCQjw5eX7BRDQARIsAMhYLP87WaQFDhmbBYRR_GhM5C6MKuh4oV6A8h4AT2MoEnOJj9tUcuSsWE8aAvMyEALw_wcB)
We are having trouble getting the old bolts of the old flanges.. we may have to axel grind them off! I'm blaming my friend Louis for rounding off one of the nuts
Thankyou all for such useful information! Neither myself or my friend have the tools for or have done brazing before... will it harm much to use the old flanges with new bolts in? Or if it is important will have to save up some money for a professional. Some better photos attached...
Hi All, I have finally had time while the boat is in for dry docking to unwrap all the heat wrap. Looks like the exhaust pipe has split before the clamp fitting? Any suggestions what I need to do? Warmly Tom
I have an SR2 lister engine in my boat. There is sometimes smoke coming out of the exhaust thing, see on the photo where smoke marks are around the material wrapped around. Should I be worried? does it mean its cracked in there?
Thanks Alastair and Alan. I may well try and get the hose over the olive but i'd need to be able to move the nut back in order to fit a hose clip behind the olive as there isn't much room at all at the moment
Thanks everyone for such swift responses. The inside diameter of the hose pipe is 13mm. 'Bodge' job Jen sounds apt as the the hose pipe kept flying off hence why I was tightening it so much
Hi, Does any body know the proper name of this copper pipe end fitting as I need to get a new one (and where I could get one) as its collapsed under the pressure of the jubilee hose clip that connects my shower up in narrow boat. The end part is 1cm wide and the pipe is 1.5cm. Any help would be much appreciated as i'm without water at the moment unless I can cut off water to shower somehow. See photo..
Warmly Tom
