Update:
1.) I read the instructions on adjusting the throttle lever but do not have the aptitude to make the adjustment as I had difficulty in separating the cable unit from attachment point and did not want to screw it up. I do not know how to adjust the throttle cable and may need a mechanic on site because:
A.) (Note: the Shut Off Lever which normally has a cable from the helm instrument panel to shut off the engine from the cockpit is now shut off directly by hand on the engine as the shut off cable was damaged and removed)
The Shut Off (fuel) Lever seems to be moving downwards to the 'on' position on its own more readily compared to before when you pulled the lever back to cut off the fuel it would seem 'stiffer' and stay in the 'off' position. I still push it down all the way before starting the engine it just seems 'looser' and more prone to want to be in the 'on' position. (Note: the fuel cut-off cable from the instrument panel was removed and the fuel lever to start the engine is moved 'UP' position directly by hand now)
B.) Normally, 'idle' is when the throttle at the helm is in the upright position. I have noticed that when starting the engine by giving it fuel/ pushing the helm throttle forward....the engine receives fuel in a greater amount as it quickly revs up as if alot more forward push of helm throttle....I have to quickly pull it back to the neutral position but even then it does not idle at the usual 6,000 rpm but it idles at 8-9,000 rpm's even when the helm throttle is pulled back into the full- upright' clicked 'neutral position. Thus it appears to be a cable adjustment which I dont seem to be able to do-
As for identifying the source of the leaking fuel:
The process I did:
1.) I started the engine up the leak appeared once the rpm's hit 2,000:
(see above schematic)
Number 48 'screw for cover' over the 'adjusting hole cover ' (46) of the Pump Housing (44) was leaking fuel. The wire that normally runs through it was broken off and the 'screw for cover' was extremely loose and exuding fuel. I used a 5/16' wrench and was surprised that it tightened over a full revolution. It was very loose.
I then started the engine again....and let it run at 2,000 rpm's for a while.......no more leaking.
However, there was still a scant fuel leak, minimal, between the Shut Off Lever (82) and the Shut Off Shaft but 98% or more of the leaking fuel was coming from the Screw For Cover (48) over the Pump Housing, but nowhere near the amount that was flowing out by the 'Screw for Cover) #48 over the Pump Housing.
Also---the wire that used to go through the screw has been broken off....
Upon running the engine at 2,000 rpm's after tightening that 'Screw for Cover' (48) no more fuel leak-
however, i did notice that when i pulled the helm throttle back to neutral.....the engine was idling at 8-9000 rpm's whereas before the new throttle cable was installed in the same position at the help at neutral the engine idles at 6,000 rpm's.
here are some pics:
