Long time since I've made a post here but circumstances have changed and my father is now the proud owner of a 57 foot narrowboat!
He purchased the boat to liveaboard since selling his house and entering retirement at the end of February, however for the last 2 months has been forced to continue living with me as we keep occurring issues on the boat.
The main one currently is with the Invertek Sinewave Combi Inverter.
He found he had no power on the boat despite it being connected to shore power (he is in a marina). We have access to the cabinet and I'm confirmed it hasn't tripped, however when removing the hookup lead I noticed water in the end cap connected to the boat, on the old lead a small slit was cut into the plastic casing to allow water to escape, something we didn't remember when purchasing a longer lead...?
It seems what has happened is the water has interrupted the AC power so the inverter has switched to battery power automatically and drained the battery bank.
After drying out the lead we reconnected everything and nothing came back on, so we run the engine and the inverter lit up, displaying 13.7v with a fast running engine.
We run it for about an hour and then stopped and the voltage simply drops to around 11v and then the inverter bleeps loudly and displays the Uvt error shown.
The AC In led is lit (Orange) and the Bypass and Inverter Leds are flashing green (hard to photograph as the inverter is in a cupboard and I have to reach in and take a photo on my phone to see it clearly); The battery LED is not and will not light up, shouldn't this be lit when shore power is connected to charge the batteries?
I will be revisiting the boat tomorrow after leaving it connected to shore power today.
Second issue relates to the Nordic Diesel Stove and 'central heating' system. (I don't have pictures of this currently, sorry)
The boat has one of these stoves https://www.ruralenergy.com/heating-equipment/var-nor250-nordicstove-25000-series
Connected to it is pipework running to 4 radiators via a pump which appears to have power (switch is lit up) but doesn't seem to come on to move any water around, the pipes get hold up until the pump but no further, there is black/white thermostat next to this but adjusting this or the switch on the pump itself doesn't appear to make a difference. We have already tried bleeding the radiators. The stove ignites and kicks out a good amount of heat, this issue occurred before any issues with the inverter.
Any help would be appreciated, we are in March, Cambridgeshire btw.
Thank you!
